Thread: lights on
    Jul 2011
    UK
    Year : 06
    Default lights on
    Seen a vectra today and he unlocked the car and headlights and rear lights came on how do ya do this Ano number plate light comes on when unlock
    5 Post(s)
    Number plate lights coming on when unlocking have always been standard on Vectra-Cs.
    As for the headlights and rear lights, maybe he's fitted a happylightshow device.
    Regular Member toaffer's Avatar
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Engine : 1.8 VVT (Z18XER)
    Mileage : 73K
    Howdy!Just a niggling query I come home from work this morning and switched ignition and lights off and locked the car as asual!I noticed the headlights and reverse lights were still on with the usual reggy plate light??? I put key back in ignition and started her and then switched her off and everything was off? did I do anything to cause this or is there a possible fault? e.g. the ignition barrel did not pop out properly when key was released? cheers,toaffer
    Feb 2011
    Selby
    With the ignition off, if you open the door then flash the headlights, the dipped beam and reverse lights come on for 30 seconds even after you lock the doors. This is so you can see your way to your front door etc if it's dark.
    It's in the Owner's Handbook.
    Sep 2011
    Fife,Scotland
    Trim : SRI
    Mileage : 73K
    Quote Originally Posted by rich r View Post
    Cheers Rich R,another hidden talent of the Vec C exposed(or just me bein lazy and not lookin in the handbook) Qualitee
    Jan 2010
    S/W Scotland
    Thanks for that
    5 Post(s)
    If you leave the drivers door ajar then the lights will stay on for approx 2 mins - also mentioned in the handbook.
    Feb 2011
    Selby
    It is indeed. Page 17 in the pre-facelift manual:
    Operating door-to-door lighting:
    Key to position 0 and remove, open driverís door, pull turn signal stalk towards steering wheel.
    Dipped beam and the reversing lights light up for an additional 30 seconds after the driverís door is closed.
    If the driverís door is left open, the lights will go out after two minutes.
    Door-to-door lighting can be deactivated by inserting the key in the ignition switch or by pulling the turn signal stalk towards the steering wheel again while the driverís door is open.
  1. Brighter Lights for side lights, Vectra SRI150
    By 150_SRI in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2011, 23:50
  2. Replies: 2
    Last Post: 31st March 2010, 13:30
  3. Philips bluevision h7 head lights & side lights brand new
    By davidlewis24 in forum Parts for sale
    Last Post: 19th March 2009, 22:42
  4. Dark lights and Rear Lexus lights finally fitted
    By Leviathan in forum Styling
    Last Post: 29th February 2008, 22:35
