Thread: Hesetation in 2nd gear.
    Sep 2009
    Glasgow
    Default Hesetation in 2nd gear.
    Hi all seem to not get a lot of power in second gear, every other gear is fine, don't think the clutch is slipping as i can boot it in 3rd and it boasts away right up to 70, tried testing clutch by driving at 20 mph and then putting it into 5th the car slowly accelerated and doesn't just rev, any ideas what's wrong
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Not sure about the 1.9 but the 3.0 is limited to the amount of power/torque it can put out in lower gears, this is to protect the gearbox, clutch/flywheel.
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by nokiaman1978 View Post
    I've got the 120 cdti and that has a flat spot for a split second when I change from 1st into second - all other gears are fine and it doesn't bother me too much
    Regular Member Exclusive BV's Avatar
    West Midlands
    it's not an exhaust issue is it, front flexi blowing?
    might be affecting the boost at lower revs
    West Midlands
    Sep 2009
    Glasgow
    will check out flexi pipe, ta mate, just started happening so not an issue with power being reduced in lower gears, thanks for the info.
  1. cdti stiff gear change, removing gear turret?
    By IrishVectra in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2017, 03:14
  2. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  3. Reverse gear - weak spring on gear stick
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th December 2011, 13:18
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Vec C 52 plate 2.2 Dti Gear Stick Jumps out of 1st gear on take off
    By ukwanderer01 in forum Engine & Drivetrain
    Last Post: 5th July 2009, 21:43
