Thread: front bumper / headlight help
    Nov 2011
    birmingham
    Default front bumper / headlight help
    Tried to change my front indicator can read up that the front bumper needs to be removed so i an change the indicator bulb. The car is a signum 55 reg facelifted and i've manage dto unscrew the 2 screws under the front wheelarch and the blots at the light unit at the top but can't work out whats holding the buper on
    Any advice and pictures would be appreciated
    Regular Member Keif's Avatar
    In the Garage
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Moved to correct section !
    Irmscher Insignia CDTI 130
    8 Post(s)
    Remember when undoing the upper torx bolt in the wheel arch to push it in before totally unscrewing it. ie unscrew it half way, then physically push it in. Doing so will then unlock the wing from the bumper.
    Nov 2011
    birmingham
    cheers will give it another go when i get time this weekend most likely. Hopefully its just what you advised that will get my bumper to come off. But have read the how 2 listed above and mentions disengaging the bumper from the supports, not enitrely sure if this is easy or how to carefully do does and how much force is needed. It seems like a bad design of whats required to just change the indicator bulb
  1. Signum front bumper (Vectra c pre-facelift sri bumper) rubber skirt
    By 2.2 DTI SRI in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2012, 20:23
