Thread: 1.9cdti 120hp REAL engine code?
    Regular Member cphaza's Avatar
    Hertfordshire
    Default 1.9cdti 120hp REAL engine code?
    Howdy peeps
    Before you all jump in and say "Z19DT", let me explain.....
    The water pump has siezed solid on our vec (i know its normally the 150bhp 16v lumps that do it...im just the unlucky one!) and it dropped the belt because of it. Im gonna buy another head as most of the valves and guides are goosed plus the threads for the glow plugs are gone. Now the reason I am asking the engine code is because i know they fitted these exact same engines into some fiats, so if i can find out the fiat engine code/part number/etc.. it broadens my searching criteria as there seem to be alot of 8v diesel fiat heads about which LOOK the same from pictures but obviousley i wanna be sure!
    Cheers for any input chaps
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    they dont look like a Fiat engine they are a Fiat engine, they are also used in the Alfa Romeo
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by husky View Post
    [ame="http://en.wikipedia.org/wiki/JTD_engine"]JTD engine - Wikipedia, the free encyclopedia[/ame] - Fiat JTD engine - by means of the GM Powertrain engine-sharing agreement with Fiat
    Hertfordshire
    Thanks for stating the obvious Perhaps i didnt make it clear enough so i will try and clarify. My point is that there are several different 1.9 fiat lumps fitted to all sorts of cars (yes, fiat and alfa's!) and was wondering if anyone was familiar with rebuilding them and would know which fiat engine codes directley correlate to the z19dt in the vectra. From physicaly looking at some cylinder heads off varying fiats i can see that they look similar to the one off my z19dt but many have different bhp's and other things besides. Hence my asking if anyone knows which EXACT same head would be found on what fiat.
    South east
    You need to search for a "JTD 120"
    Engine : 1.9 CDTi
    Not sure if its the same for the 120 but the 150 brakes rockers rather than valves so the head doesn't need to come off
    Hertfordshire
    It bends the valves unfortunatley. the head is in a bit of a state what with needing 6 valves, the guides, re shimming and the glow plugs threads helecoiled. From what i can see, the 115bhp lump is the same except the vectra has different cam lobes. More investigation needed........
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Keep searching/trying ebay, they go from £100 complete & sometimes already tested.
  1. engine FAN problems 1.9 (120hp)
    By vectrawhite in forum Vectra C / Signum Troubleshooting
    Last Post: 21st May 2012, 20:52
  2. 1.9CDTi 8v 120hp Cylinder Head Replacement
    By cphaza in forum Engine & Drivetrain
    Last Post: 30th December 2011, 02:31
  3. Replies: 27
    Last Post: 30th July 2011, 17:59
  4. I Need a Fault Code Reader for 06 1.9cdti
    By thefibreguy in forum Diesel Engine related
    Last Post: 31st May 2010, 18:44
  5. Vectra 1.9cdti (150) and using U581 code reader
    By markluk in forum Vectra C / Signum Troubleshooting
    Last Post: 6th April 2009, 17:28
where to find engine code vauxhall vectra 1.9cdti
z19dt fiat engine code
1.9cdti 120 engine code location
Vauxhall Zafira 1.9 CDTi 120 JTD
