Thread: Maf cleaning
    Regular Member jofenan's Avatar
    nottingham
    Default Maf cleaning
    My veccy threw up a maf low reading (or something along those lines).I was giving it a good thrash. Changing from 5th to 6th at about 95 ( private road of course! ) No obvious leaks so garage just reset it and it's been fine since although I have taken it a lot easier. Have been looking around the net and the fiat boys can clean their jtd's maf. Two screws and it slides out the housing and they clean it with alcohol and a cotton bud. The veccy one looks the same but it's a push fit. Is it possible to slide it out the housing or is it in there pretty solid??
    Did a quick search on here and the only thing I found was to spray it with carb cleaner. Seems a bit hit and miss??
    Jon
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Not recommended to touch the MAF sensors with anything .
    Isopropyl is recommened to clean the MAF wires. Remove the MAF sensor from the round MAF housing/pipe and spray isopropyl over the whole of the sensor. Leave to dry completely and refit.
    HTH
    Linky to Maplins http://www.maplin.co.uk/isopropyl-alcohol-28994
    nottingham
    nottingham
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    That's basically the idea but those MAF wires down the bottom that you can't see are very fine. Over cook it with the cotton bud and it'll be new MAF time .
    JMO .
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    As mentioned its a very fine wire smaller than a human hair sensing.
    You can spray small amounts of contact cleaner to clean it. But be carefully and leave it to dry naturally
    wirral
    36 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Nov 2011
    cornwall
    I have been using this stuff for years to clean out MAFs works wonders
    http://www.ebay.co.uk/itm/2-x-CHOKE-...item3cb8227a8f
    and at my local market its only 99p
  1. Cleaning egr
    By morrisseyno1 in forum Vectra C / Signum Troubleshooting
    Last Post: 4th September 2011, 20:16
  2. egr cleaning
    By hbomb in forum Engine & Drivetrain
    Last Post: 8th July 2011, 18:00
  3. cleaning help
    By davidlewis24 in forum Detailing and Car Care Discussion
    Last Post: 13th April 2009, 20:37
  4. DPF Cleaning?
    By parapaul in forum Diesel Engine related
    Last Post: 9th October 2007, 13:52
  5. Cleaning
    By thegoldenbullet in forum Detailing and Car Care Discussion
    Last Post: 11th August 2007, 22:13
