Thread: 2.0 Turbo Cold Start Vibrations / Misfire
    Apr 2009
    Aalborg
    Default 2.0 Turbo Cold Start Vibrations / Misfire
    Hi guys,
    I am looking for some advice for my 2.0 Turbo (2008) that has developed a rattle / vibration and slight misfire when starting from cold - when it warms up after a few minutes and on subsequent restarts there are no issues (only seems to have developed as the temperatures outside have dropped). Also the car drives well still, had a blast down the Autobahn to Hamburg last week and still accelerates well and tops out around 145 mph.
    I am not sure if this is relevant but it had car underbody rust treatment done by Dinitrol 1 year ago and a few days after I noticed that the Exhaust Sensor Warning light came on but when I restarted the car it went off again. Now periodically every few weeks or months it comes on again - not flashing just constant but goes out the next time I start the car.
    The car gets used mostly on motorway I drive about 500 miles a week from one end of Denmark to the other and it is serviced every 6 months and just a few week ago pasts it its MOT for the next 2 years.
    The wife is beginning to moan at me about selling it and getting a Fiesta Diesel that does 27 km/l due to the distance I drive, the money I may have to spend fixing it and that I just got a speeding ticket from a Mobile Photo Van for driving 76 mph in a 50 mph (in my defense the road was clear, a long straight and I accelerated to pass several lorries - just near the end of the straight was the van - which was hidden behind a lorry and from the picture I am clearly overtaking as I was moving back in) but what can I say ... "I have a heavy right foot" too and am impatient
    Therefore before I lose my modded, beloved Vectra I need some more advice (Caveman_Nige pointers have helped) - Anyway onto what I have done so far:
    • I cleaned the MAF with some brake cleaner and visually it looked ok
    • I cleaned out the air box (modded already) and changed the air filter
    • I cleaned the sensor on the pipe leading to the throttle body
    • I cleaned the throttle body in situ but it really was pretty clean already
    • I fired some carb cleaner through the air intake which the engine was running
    • Yesterday I changed the spark plugs again as I had already done it 6 months ago after a service. The spark plugs themselves were black as hell - so it looks like it is running rich - as I can't believe they can build up that much coking in 6 months?
    • I swapped coil pack 1 & 4 with 2 & 3 to see if it made any difference - It didn't
    I have a CTS Coolant Temp Sensor from a SAAB on the way and will fit that anyway (only cost a tenner).
    I have run diagnostic and the only error was P1312-00 misfire on cyl 1 or 2 but once cleared the error code has not returned after a week of cold starts.
    I am thinking now of that if it is running rich then maybe the sensors got fouled when the under body treatment was done and I need to replace some sensors (how many on 2.0 Turbo) or as Caveman_Nige pointed out it may be the coil pack.
    The cheapest way to replace the parts would be helpful as I don't want to end up with a Fiesta 95 BHP diesel - Any advice and relevant part numbers appreciated!
    TIA
    Alistair
    Apr 2009
    Aalborg
    Anyone ... come on guys ... I don't want to end up with a 1.4 Fiesta Diesel !!!
    South east
    Which spark plugs did you fit when you changed them?
    WGAF#5
    the cylinder misfire is the underlying cause on the judder..
    The insulator foot section and electrode section are covered with dried, soft black carbon.
    [Results]
    Poor starting, misfiring, acceleration defect.
    [Cause]
    Repeated short-distance driving (driving with the engine cool), incorrect choking (overly rich air-fuel mixture), injection timing delay, plug heat range too high.
    i would recommend the plugs be changed to see if the result is different BUT the underlying cause if not diagnosed above needs identifying .... it could also be down to prolonged driving at higher speeds on the autobahns ... so maybe fit a hotter plug
    Apr 2009
    Aalborg
    I fitted the standard set of NGK PFR6T-10G plugs at the weekend and didn't make any difference.
    I did notice a Petrol smell when I started up yesterday like it is running too rich so maybe changing the lambda sensors is what I should do next?
    Can you use any universal vauxhall 4 wire lambda sensor? Anyone got the part numbers for a 2.0 Turbo?
    TIA again
    Apr 2009
    Aalborg
    Well I gave up trying to diagnose this and took it to Opel - As they saw no error codes on Tech2 and then they said there was nothing wrong with it ... but as I told them I can feel it on a cold start and was adamant ...
    Left it there overnight Sunday and they started it up Monday morning and they felt the cold start juddering ... their opinion is that it is exhaust valve that is damaged and it will need a £1700 top end overhaul so it looks like the Vectra is on the way out
    Any way of testing this?
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    How have they gone from a misfire on a couple of cylinders to an overhaul? Dodgy!
    I had the same problem on my Hyundai accent after new plugs and leads... ended up being a lead arcing out on the coil pack on cylinder 3... only did it when cold and not every day (moisture in the air). If its 2 cylinders I would be thinking leads/coil pack?
    Regular Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    Double post bug.
    Jun 2009
    South Coast
    I asked vauxhall about it when I had mine doing this. and they did not have a clue either. I changed one coil and it cleared up. Montshs later I had a similar thing so I changed another coil and it went away again. I now keep a spare coil feady for when the next one goes. These things wear out mate. I believe our friends with 2.8 engines have coils changes stipulated at certain milage service intervals, about every 60k I think.
    The parts guy at vx was interested to hear my results as his son's car was doing similar things and he then did a coil change as well and solved his.
    The first coil I bouvht from vx brand new the others I bought used from Neo Brothers.
  1. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  2. misfire when starting from cold
    By bert01909 in forum Engine & Drivetrain
    Last Post: 15th August 2011, 19:51
  3. Slight Misfire & (Intermittent) No Power When Engine's Cold (1.9 CDTI 150)
    By DanR in forum Vectra C / Signum Troubleshooting
    Last Post: 11th March 2011, 21:13
  4. Smoking Turbo from cold start 2.8 V6???
    By luke4487 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 16:59
  5. misfire and belt noise on start up
    By vectragsi3.2 in forum Engine & Drivetrain
    Last Post: 11th November 2007, 20:57
insignia diesel misfire when cold
2.0 turbo signum rattling noise on start up
corsa c starting misfire when cold
insignia misfire when cold
signum 2.0 turbo misfire
