Results 1 to 10 of 15
Thread: Noisy Boiler
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    Default Noisy Boiler
    Does anyone know anything about heater boilers
    Mine fires up ok runs perfect for 15 mins then starts making this horrid noise
    It makes this noise for about 5 mins then goes of
    if when its making this horrid noise I turn the hot tap on or undo a bleed screw on the radiator it also stops
    Its a combi boiler about 9 years old I have been advised that it may be air in the system and it also needs some inhibitor of some sort
    thanks in advance for any help
    Regular Member HITFACTORY1403's Avatar
    Mar 2011
    NEWCASTLE UPON TYNE ( Shiremoor )
    before i got to your last sentence i was going to say air lock .
    i have the opposite to you on my combi boiler ,
    when i run my taps , i can hear the pipes going ... clang clang for a short time .
    maybe , when you run the taps or undo your bleed screw on your combi , you are pushing through the air or letting the air out , thus causing the noise to stop .
    thanks , you have reminded me , that i need to bleed my radiators , as some are very hot and some are warm and one is cold .
    i hope you get it sorted ,
    sorry i can't be of much technical help .
    Oct 2010
    lincs
    Quote Originally Posted by HITFACTORY1403 View Post
    when i run my taps , i can here the pipes going ... clang clang for a short time .
    by what you have said its all pointing to an air leek
    Norwich
    Trim : SXi
    Engine : 2.2
    It sounds like cavitation in the pipes. The air cycles round with the water gets to the pump and the pump then chatters (cavitates)
    There should be a way of topping up the boiler but do this when its cold. Fire up the boiler and bleed out the rads. Some pumps have a bleed on them as well if yours does bleed it from here as well.
    Oct 2010
    lincs
    Quote Originally Posted by the_wave_rider View Post
    we have a tap on our boiler to pressurise the system
    i built up the pressure to 1 bar yesterday and have noticed that the pressure has dropped down today (half way between 1 And zero)
    this would indicate that we have a leak somewhere
    would you agree with this
    Regular Member poves's Avatar
    lancashire
    Quote Originally Posted by crispy007 View Post
    My father in law is well clued up on stuff like this ( commercial heating engineer)
    I'll ask him later , but that pressure is definately too low mate .
    Can't remember the exact way it goes but it's something like 1 bar pressure will service a given distance of pipe of a specific diameter (a guess would be 20ft for every bar)
    I don't really know much more , sorry .
    Oct 2010
    lincs
    Quote Originally Posted by poves View Post
    Ok thanks for that mate
    Norwich
    Trim : SXi
    Engine : 2.2
    You need to be running more than 1 bar! Check around the pipes at the thermostats on the rads as there may be a small leak. You are obviously losing water somewhere for the pressure to drop
    Jan 2010
    wirral
    I'd say 1 bar in a combi is sufficient, although I'd opt for somewhere nearer to 1.5 bar (when the system is COLD). Also, check your overheat stat, if the boiler is running for a while and cutting out. The most obvious cause would be an airlock though, but with a combi being a sealed and pressurised system, this should be easily cured. As said, pressurise the system to 1.5 bar when cold and try bleeding all yours rads, also worth checking your auto air vent inside the boiler.
    Norwich
    Trim : SXi
    Engine : 2.2
    Most boilers won't even fire up at 0.5bar pressure. Modern day combi boilers run at around 1bar cold and upto 2bar when used. If the pressure is too high when the boiler is cold it will cut out when running or over pressurise.
  1. Boiler sorted !
    By bembo449 in forum The 'Off Topic' room
    Last Post: 22nd July 2011, 22:23
  2. Combi Boiler!
    By djr69uk in forum General Chat
    Last Post: 5th March 2011, 02:04
  3. Gas boiler broke? or is it?
    By spoons in forum General Chat
    Last Post: 22nd September 2010, 13:46
  4. Duff Boiler.....
    By macdad in forum General Chat
    Last Post: 23rd February 2008, 21:38
  5. Choosing a new Boiler
    By Brocks in forum General Chat
    Last Post: 28th March 2007, 23:15
