Thread: Help please with washer jet problem!
    Sep 2011
    Derby
    Default Help please with washer jet problem!
    Hi,
    Im having problems with my washer jets and would like some help/advice before the really bad weather comes.
    When i go to use the jets the spray from them is useless, screen wash comes out of the jet but just reaches the bottom of the windscreen.
    Could there be a blockage? is there a filter that will need cleaning? where is the washer bottle? and guides on how to locate?
    Any help very much appreciated.
    VECTRA1974*
    Guest
    have you changed you jets to the insignia ones?also have you looked on the how to section on the forum
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Yes there's a filter on the tube at the bottom of the pump where it fits into the washer bottle. The bottle is under the passenger side wing, easiest way to get to it is underneath, but if you want even more room, pop the front bumper out.
    Pop the pump out and you'll see a rubber piece it fits into that has holes in it, they'll probably be blocked, its very common.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Quote Originally Posted by Ian-Highlander View Post
    north east
    Chuck some dettol in the bottle or a sterident if your of that generation
    8 Post(s)
    You could always try using the how2
    http://www.vectra-c.com/forum/showthread.php?t=107593
    Sep 2011
    Derby
    That's a great guide there! Didn't think there would be a how to on this, plus the search function doesn't work on my phone. Thanks to everyone for the help!
  1. pressure washer problem
    By MACVVT in forum Detailing and Car Care Discussion
    Last Post: 2nd July 2012, 22:07
  2. wiper and washer problem
    By Roberto1981 in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2012, 20:26
  3. headlight washer problem
    By ditchp in forum Electrical & ICE (including SatNav)
    Last Post: 21st July 2010, 22:06
  4. Washer Problem AGAIN
    By craig-k in forum Vectra C / Signum Car Chat
    Last Post: 20th May 2009, 22:16
  5. window washer problem
    By patrick1062 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2008, 17:47
