Thread: Injector seal gone??
    Jun 2009
    Chelmsford
    Default Injector seal gone??
    Had the sound of a strangled budgie coming from the car over the last couple of days, took the engine cover off tonight and noticed its blowing out of one of the injectors (far right), guessing its the copper seal gone, any idea if this is an easy job to change yourself??
    Aug 2011
    Devon
    yes but its a pain as you will have to remove all the pipework from the injectors first. also the injector will takes some effort to remove but it can come out by hand (trust me). is it the 120 or 150 you have?? there is a good tutorial on here for removing them, the copper washers are quite cheap from VX too.
    Jun 2009
    Chelmsford
    Its a 05 1.9 CDTi 150. i'll check out the how to section then, thanks
    Aug 2011
    Devon
    no worries if not PM me and i can help but the how2 is pretty good tbh
    Jun 2009
    Chelmsford
    Apparently Vx recommend you change the pipes when you remove them! Is this necessary??
    Aug 2011
    Devon
    nope, mine are all fine still after removing all injectors and getting them cleaned no leaking from the pipes just make sure everything is done up nice and tight
    Jun 2009
    Chelmsford
    Cheers, i'll tackle it it the next week then!
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Very common for them to go and almost always that injector next to the battery. Just don't drop anything in the cylinder :P
    Jun 2009
    Chelmsford
    Well just done the work, thought it was gonna be hard, as injector didnt want to move then suddenly out it popped, cleaned up new seal, job done in 45min, Couple of attempts to start, now running sweet just been on 30 mile drive and what a difference its made.
  1. 2005 Vectra 1.9 CDTi 150 injector seal
    By MXB74 in forum Engine & Drivetrain
    Last Post: 11th March 2012, 18:38
  2. Help!!! Injector seal problem 150cdti
    By scrumpus in forum Engine & Drivetrain
    Last Post: 18th November 2011, 20:03
  3. is changing the injector seal on a 2.2DTI a DIY
    By peadar in forum Diesel Engine related
    Last Post: 21st April 2011, 20:26
  4. Injector Seal Replacement
    By siz1 in forum Engine & Drivetrain
    Last Post: 24th March 2011, 10:53
  5. Possible Injector seal maybe????
    Last Post: 12th November 2010, 20:53
