Results 1 to 10 of 13
Thread: Fog Light not working but bulb is fine?!?
    Regular Member jordib's Avatar
    Londonderry/Dundee
    Default Fog Light not working but bulb is fine?!?
    Hi there
    My passenger side fog light hasnt worked in a while and ive had that annoyin warning light in my dash since it went out.
    I changed the bulb the other day, the bulb had blown but when i put the new bulb in it still wont work, i took the new bulb out and it worked fine when i tried it but when it was in the car it doesnt work and the warning light is still on.
    Really starting to annoy me now, does any1 know what else wud stop it from working and how i can fix it?
    cheers
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    I would try and clean the connections ..maybe the socket has even come undone.
    Mileage : 000
    I take it the contacts are clean.
    Aug 2010
    Leeds
    Have you a 12v feed?
    Good tips above clean all contacts with wire wool or emery cloth.
    Londonderry/Dundee
    il try that, i dont think anything has come lose the housing all seems fine, il try cleanin it tomorro mornin.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    As you say it's passenger side, I have to ask.... are you sure it worked in the first place ? We all know as standard it's only the driver's side foglamp that is connected, but just in case you've not wired in the other one, I thought it best to ask...
    Londonderry/Dundee
    lol yea it used to work
    just stopped a few weeks ago
    Londonderry/Dundee
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Always nice to rule out the silly...
    .... but if it didn't work with a new lamp fitted, I'd be out there with my multimeter... just checking out power supply, earth, continuity, security of mounting and all multiplug contacts...
    11 Post(s)
    No one has asked yet as far as I can see.
    Is this the front or rear fog light?
    If rear, then by default only the drivers side is wired up.
  1. Brake Warning light and display error message , BUT BRAKE LIGHTS ARE WORKING FINE
    By JACKALG1 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2013, 18:56
  2. Sidelight not working but bulb is fine?
    By Drazek in forum Electrical & ICE (including SatNav)
    Last Post: 24th June 2012, 11:39
  3. Replies: 2
    Last Post: 29th January 2010, 11:51
  4. Can I Replace Fog light Bulb for a 100 watt Bulb
    By m300raj in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2010, 19:33
