Thread: loosing key signal on my wifes 04 zafira
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : ELITE
    Trim : FULL LEATHER
    Engine : 1.9 CDTI 150 BHP
    Mileage : 87,000
    Default loosing key signal on my wifes 04 zafira
    at first i thought the key needed a new battery so changed it , went for a wee while then same again but if i reset it (key in ignition dash lights on and press the lock button on the key ) and it goes for another wee while .
    so tried the spare key but it still does the same any ideas
    11 Post(s)
    Usual culprit is a dry joint on the battery connector. You can either try soldering it, or place a thin piece of card (or folded post-it note) on top of the battery to push it down a bit harder when the lid is in place.
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    thanks i will try that
    ijk571
    Guest
    Thats what it is, both my keys on my 04 DTi Zaf do the same thing, the battery holder has come right off the pcb due to knackered solder joints. I pack it in with cardboard to hold it in place and it seems to work.....
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Had this with my wife's spare key to the Vec, reset it half a dozen times, eventually it stayed set.
    11 Post(s)
    Just remembered about a thread on a forum I used to look at regularly until they updated vBulletin, but that's another story.
    Here's the thread showing the solder fix - but you'll have to register to see the pics.
    http://www.vauxhallownersnetwork.co....d.php?t=123630
    Aug 2007
    Vehicle : ELITE
    Trim : FULL LEATHER
    Mileage : 87,000
    thanks people i will try the cardboard tonight
  1. Poor fm signal
    By Scoobycarl in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2013, 00:01
  2. fitting a clutch in the wifes zafira A
    By peadar in forum General Motoring Chat
    Last Post: 30th December 2011, 17:28
  3. where can i get an RPM signal?
    By Caveman_nige in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2011, 18:00
  4. GPS signal
    By bigmac in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2010, 20:07
  5. No GPS signal For Sat Nav
    By steve74 in forum Electrical & ICE (including SatNav)
    Last Post: 28th July 2007, 22:08
