Results 1 to 2 of 2
Thread: zafira glass replacment
    Regular Member myelite150's Avatar
    Nov 2009
    south wales,Cwmbran
    Default zafira glass replacment
    hi all
    i wanted to know has anyone got a clue on how to replace the small quarter glass section on the rear door please
    regards all
    Regular Member poves's Avatar
    lancashire
    Remove the door panel , screws along the bottom edge and some behind grab handle , tweeter cover and ashtray possibly.
    Pull away off the poppers and then slide the panel upwards off the top lip of the doorskin.
    Unplug the speaker clip , the window switch if it's electric and maybe the courtesy lamp connection on the bottom of the panel.
    If the window is manual you have a circlip behind the winder spindle to remove (carefully , otherwise it will ping off and land a mile away never to be seen again )
    Peel back the plastic membrane and send the window all the way down , there should be a screw inside the rubber lip at the top edge of the bar , after you pull the rubber window trim out of the frame you should see this.
    Then there will be one or two lower down , take the bar out from the top and you should be able to replace the glass and replace the bar without to much hassle.
    There is a rubber gasket around the glass I think , which you need to re-use although I may be wrong , but it will be obvious to you.
    Also if you struggle getting the bar in or out you may need to take the drop glass off the mechanism to give you more room.
    I know it's a bit sketchy but this is a vectra forum , If none of that makes any sense , take it to autoglass and let them do it .
  1. Fog lamp replacment
    By rheumatoid in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2012, 15:08
  2. Drivers side mirror glass replacment needed
    By eaglepva in forum Bodywork & Interior
    Last Post: 31st August 2011, 09:21
  3. Air con compressor replacment
    By Rickiw in forum Engine & Drivetrain
    Last Post: 8th June 2011, 18:35
  4. Horn Replacment
    By jmacp in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2009, 17:12
