Thread: Rear Hatch Lights Plug
    Lincs
    Default Rear Hatch Lights Plug
    Vectra Estate. Offside inner tail light went out on me last night. I removed all the hatch panel and replaced the bulb. This made no difference. On closer inspection the bulb dimly fades in and out.
    I removed the little black plug that feeds all 3 bulbs, cleaned and WD40;d it and clipped it back. It's fixed it, but the plug has corrosion on it.
    Can someone please post me a link for a correct replacement
    Thank you
    Paul.
    Lincs
    Bump, please.
    Sounds like my problem, tail lights on the driver side are dimmer than the ones on the passenger side, swapped the bulbs over and see that the bulbs are fine, dim bulbs brighten up on the passenger side and passenger bulbs end up dull on the driver side. They also appear to flicker a little, fading in and out - I'll take a look at that cable tomorrow and if I manage to get it sorted I'll post you something, let me know how you get on buddy
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    You can get replacement bulb holders for the estate individually (http://www.ebay.co.uk/itm/2509239602...84.m1423.l2649) but not sure about replacing the plug seperately.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Get a tiny file set from the likes of Aldi an gently clean the corrosion off and use some contact cleaner too.
    failing that go to a scrappy an cut one off
  1. saloon and hatch rear lights , same fitting ?
    By poves in forum Bodywork & Interior
    Last Post: 29th March 2009, 21:21
  2. 2004 hatch rear lights
    By addyboy1982 in forum Parts for sale
    Last Post: 26th October 2008, 01:23
  3. Vectra hatch rear lights..
    By danBoy in forum Vectra C / Signum Car Chat
    Last Post: 25th October 2008, 21:06
  4. Saloon v's Hatch Rear lights
    By rsorion in forum Styling
    Last Post: 18th September 2007, 19:52
