Thread: MAF test results(multimeter)
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default MAF test results(multimeter)
    Ive just tested my MAF with my multimeter set on restiance and came back with the following results:
    Pin 3 844
    Pin 4 834
    Are these the normal results or is the MAF faulty? Theres no fault lights comming on but my car is drinking fuel like a fish and the MAF is the last possable cause i can think of
    Thanks in advance
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Justin - I've got my MAF out the car at the moment to give it a quick clean.
    If you can tell me how you're measuring the resistance, I'll compare with mine from a V6 CDTi - should be the same. Is it still fitted in the car and you're using one of the multimeter probes to a ground/earth point on the car without the MAF wiring connected?
    Aug 2011
    Basingstoke
    Trim : SRI
    Hi mate,
    I tested mine mby putting the red lead on pin number 2 and then the black lead on pins 3 and then 4.
    I treid different combo's of pins but non gave any readings
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Haven't forgotten this one, just been really busy. Will let you know asap.
    Having read a few posts on the net, not sure ohm readings mean much and MAFs really need to be read with an oscilloscope .
    Aug 2011
    Basingstoke
    Trim : SRI
    Thats ok mate.
    I read the same thing while searching to be honest as i think the readings will be different depending on the tempreture where you do the readings i.e indoors or outside.
    Im hoping all my car troubles could be down to the alturnator and not MAF
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    You need a scope to test ideally mate. You could check voltage by back probing.
    Can you get it diagnostic live reading. Should be able to see the graph an see if it's okalong with everything else at same time
    wirral
    58 Post(s)
    Trim : Basic
    Engine : 1.9
  1. What multimeter
    By SEANYboi in forum Electrical & ICE (including SatNav)
    Last Post: 8th January 2013, 23:30
  2. Compression test results on Z22YH......
    By Nik in forum Engine & Drivetrain
    Last Post: 3rd August 2011, 14:09
  3. Multimeter
    By chris1804 in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2011, 21:03
  4. can anyone recommend a multimeter?
    By sheepish in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2010, 13:38
  5. Test Results.
    By Caterman in forum Comedy & Humour
    Last Post: 13th April 2007, 12:36
