Thread: 314 setup and 345 discs?
    Regular Member colalowe's Avatar
    in the North
    Default 314 setup and 345 discs?
    at the risk of sounding stupid, what is the difference in the brake setups between the 314 and 345, I understand that the discs are bigger so is it just a bigger carrier and the same calipers??
    Wondering lonely as a cloud
    25 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Yes mate the carriers are slightly bigger as obviously are the discs, I think the pads are the same, however there seem to be 2 sets of 314 calipers one that is used on the 345 setup and one that is not, a member on here explained that the calipers for the 345mm setup have a slightly cut away or flared leading and trailing edge.
    Regular Member scotty84's Avatar
    Dec 2010
    Boosting in W.Mids
    Vehicle : Saab 9-3 Aero
    Trim : Aero
    Engine : 2.8 Turbo V6
    Mileage : 62000
    Quote Originally Posted by colalowe View Post
    Thats what I was told buddy, I have the 314mm setup. I asked a vx mechanic and he said I would need the 345mm carriers to fit the 345mm discs. Its the same caliper and pads used on the 345's as the 314s.
    It is something I plan on doing next year once winter is over and get bigger alloys. But I do believe it is possable to get 17" alloys over the 345mm setup, im sure someone on here did it.....
    Regular Member Sebastian's Avatar
    Electric Heated Recaro Leather
    36 Post(s)
    Engine : 1.9 DTH
    no guys.......
    pads are deffo different ......
    different callipers and different carries.......
    im running 345 setup and did have 314 before that........
    however there is possibility using 314 calipers with 345 carriers etc.....
    Seb
  1. what pads and discs for vxr setup
    By Dose in forum Handling & Braking
    Last Post: 7th January 2010, 00:22
  2. Replies: 1
    Last Post: 21st October 2008, 15:11
  3. Can you fit 314mm discs to replace discs on back wheels of a GSi 3.2???
    By MAF 3.2 V6 GSi in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 21:10
