Thread: Uprated Rear ARB For Vectra C
    Oct 2010
    Darlington
    Default Uprated Rear ARB For Vectra C
    I am looking for an uprated rear anti roll bar for 1.9 CDTi 150 Vectra C MY06.
    The existing bar is 19.3mm and Whiteline don't do one for the Vectra. Does anyone know the diameters for the ARB on some of the other Vectra range or do you know of a source for a replacement, uprated?
    Regular Member PORKBALLS29's Avatar
    Epping
    As far as i'm aware there is no uprated rear ARB for the Vec. My Siggy 2.8T has the same size rear and i'm pretty sure that the Vec VXR is the same also.
    as howard said , the 19mm rear anti roll is the biggest they do for the vec c / siggy
    the only way to tighten the handling this way id to fit poly bushes
    Dec 2011
    fareham portsmouth
    hello i have seen this mine rolls a bit on the back when on twisty roads or big corners how can i sort this cheers all
    exeter
    look on here this has all uprated bushes . http://www.powerflex.co.uk/products/...29-2690/1.html
    inculding the rear arb bushes
    exeter
    Sodding Typical on Sea
    Harvey,
    A common trick on the Saab's were to double the rear anti roll bar using dog-bone brackets, this wasn't something I have seen so to speak so it might not even be practical on a Vectra due to access?
  1. Uprated ARB for Vectra C 1.9 CDTi
    By Harvey Smith in forum Handling & Braking
    Last Post: 8th December 2011, 19:31
  2. Uprated Rear ARB??
    By Kev_G in forum Suspension, Wheels & Brakes
    Last Post: 26th January 2011, 19:42
  3. Uprated Sports Suspention (Rear Shocks)
    By scottymf in forum Suspension, Wheels & Brakes
    Last Post: 15th July 2010, 22:27
  4. uprated rear brakes..
    By hagga in forum Handling & Braking
    Last Post: 26th March 2010, 19:26
  5. uprated brakes..front/rear biasing?
    Last Post: 8th October 2008, 15:08
vectra c cdti rear arb
