Thread: 3rd injector conector
    slough
    Default 3rd injector conector
    anyone had a problem with 150 bhp vectra c facelift wiring conector to 3rd injector and what did you do about it ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Common fault of the 150. The dealer should be able to fix it for about £40-£90. It involves replacing the plugs. The old style are yellow but the new ones are blue.
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Replied on vvoc for you
    slough
    but i have blue and it still faulty 3rd injecter plug.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Considering yours is a facelift it should have the revised wiring/plug as standard. Are all your plugs blue?
    I would say you may well need to redo the no 3 plug or possibly you have a faulty injector
    Edinburgh
    I have facelift and mine were yellow. Had this problem a while back, kit to fix it was about £12 from dealer. 10 minutes with soldering iron. Problem solved.
    Sent from my iPhone 4S using Tapatalk
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    Quote Originally Posted by hippo View Post
    But you didn't reply in that thread and never gave that info at first,so i didn't know that
    Have you got a spare laptop ?
    Buy opcom for it and plug it in and check your injector readings
    http://www.ebay.co.uk/itm/2708066435...ht_5051wt_1233
    Or if you are sure it's the injector plug,just replace it
    Part Number from the dealer is: 93189918
    slough
    defo 3rd injector plug, i chopped it off fitted two very small lucas terminals and pushed them on the pins in the injector socket works fine
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    Ideal
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Can you give me some idea what your problem was to make you come to this conclusion ?, I have no running/starting problems at all other than a rough idle/tick-over, I have opcom'd it & i'm getting out of normal readings on 2 injectors, I'm thinking it is injectors but have no info regarding other peoples problems other than i know most have hick-ups/miss-fires at speed, Any input would be great thanks.
  1. Replies: 15
    Last Post: 27th September 2013, 00:22
  2. F10 fuse? Crimp conector
    By BooDaChris in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2013, 22:35
  3. Areial Conector
    By baldybrewer in forum Bodywork & Interior
    Last Post: 10th January 2013, 01:13
  4. Injector Wiring Loom (common fault on 3rd injector)
    Last Post: 8th October 2010, 12:18
