Results 1 to 3 of 3
Thread: Loose earth or worse????
    Regular Member Sigmacca's Avatar
    Jun 2011
    Skegness
    Default Loose earth or worse????
    Signum 3.0 V6 CDTi Z30DT Elite
    Had this a few time now where I go to start the car and the starter motor hesitates then turns the engine over and also the climate control panel dose not elluminate and fan fails to start for about 5 seconds....then it works fine
    Could it be because the xenon AFL lights are firing up on auto lights and pinching the power or just a bad earth? if so which earth points should I be checking??
    Cheers all, enjoy your weekend
    north east
    Fan and climate control check the earth point under the hand break lever.
    other good ones to check it battery t body and body to engine if you can ever find the dam thing, I resorted to a 18" negative battery lead with 2 ring connections and just ran it from the suspention torret to the engine.
    Jun 2011
    Skegness
    Thanks Roswell
    Checked all the earth points I could fine and unbolted cleaned then tightened... Couldnt see the body to engine earth, like you said if you can find the dam thing!!
    will so how it goes for now
  1. Worse job ever ?.......
    By martyngell in forum Y & Z30DT Specific
    Last Post: 2nd August 2012, 19:55
  2. White smoke getting worse and worse
    By alphabravo in forum Vectra C / Signum Troubleshooting
    Last Post: 19th March 2011, 01:04
  3. Always someone worse off than you are.
    By SignumPhil in forum The 'Off Topic' room
    Last Post: 9th March 2009, 17:34
  4. Could it of got much worse?
    By Gregg in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2008, 12:54
  5. Bad to worse!!!!!!!
    By Caterman in forum General Chat
    Last Post: 25th December 2007, 06:52
vectra c earth points
