Thread: Help!!! Injector seal problem 150cdti
    Sep 2009
    midlands
    Default Help!!! Injector seal problem 150cdti
    Hi folks,
    I have a problem I hope someone can help me with before I go nuts... I have just changed the copper washer injector seals on two injectors, but one injector just wont seal. I tightened it to the suggested torque setting which left it leaking like mad, so I tightened it quite a bit more which has had no effect whatsoever.
    I just dont know where to go from here, I cant risk tightening the clamp nut anymore, it feels like something is gonna strip if I do. Any suggestions anyone?
    Ta
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Dont know where or who does it but you need the hole/injector seat cleaning to give a clean seating area for a new seal.
    for example something like this, or maybe someone has one or can do it for you.
    http://www.ebay.co.uk/itm/BERGEN-7-P...item1c1a1d2c7a
    Regular Member 4ndy's Avatar
    Oct 2010
    Glasgow
    I had a similiar problem. The seat needs to be meticulously clean. I easily spent an hour using an old bicycle spoke trimmed off with a small rag, a jar of petrol and a compressor to blow out the debris.
    The seals are slightly cupped and I'm damned if I can remember which way up I fitted them and why.
    Sep 2009
    midlands
    thanks guys, I know this to be good advice. I spent quite a bit of time poking round with rags soaked in carb cleaner but the seats do seem to be a bit pitted. Had a look at the cutter set, maybe a last resort as I dont want steel filings in the cylinder.
    I`m going to try softening the copper washer tomorrow as I dont understand how the old ones show a definite ring where the injector has bitten into it, but after removing the new one it hardly shows any sign of bedding in even at greater clamp torque. I didnt realise they need to be in a particular way up, I`ll look into it.
    Thanks again.
  1. 2005 Vectra 1.9 CDTi 150 injector seal
    By MXB74 in forum Engine & Drivetrain
    Last Post: 11th March 2012, 18:38
  2. Injector seal gone??
    By Governor in forum Diesel Engine related
    Last Post: 4th December 2011, 15:13
  3. is changing the injector seal on a 2.2DTI a DIY
    By peadar in forum Diesel Engine related
    Last Post: 21st April 2011, 20:26
  4. Injector Seal Replacement
    By siz1 in forum Engine & Drivetrain
    Last Post: 24th March 2011, 10:53
  5. Possible Injector seal maybe????
    Last Post: 12th November 2010, 20:53
1.9 cdti injector torque
insignia injector seal problem
vectra 1.9 cdti injector seals www.vectra-c.com
vectra sri cdti injector torque
