Results 1 to 3 of 3
Thread: Removed headlight switch, now got DRLs.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Removed headlight switch, now got DRLs.
    Work this one out..........
    Had to remove the headlight switch today in order to drop the panel under the steering wheel.
    Followed the instructions to remove the switch, "disconnect -ve battery, put to sidelight position and pull out".
    Re-fitted the switch only to find that the headlights are on all the time when the ignition's on . Lights go out when key is off but none of the functions on the switch work - no front or rear fogs, no beam adjustment and the big rotary switch does nothing.
    Have I goosed the switch in some way or what?
    Edit - same as in this post http://vectra-c.com/forum/showpost.p...7&postcount=15
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Try pulling switch back out. Sounds like contacts inside are stuck
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Thanks mate, have tried that but no luck .
    But I have sorted it in the last 5 minutes .............
    Did a search on here for "headlight" and it came up with 280 hits. Went through most of them very quickly and came to #279 http://www.vectra-c.com/forum/showth...adlight+switch.
    Well I never, the switch now works .
  1. Success! Have removed the cloudiness from my headlight! *Pics*
    By v6vc in forum Detailing and Car Care Discussion
    Last Post: 12th March 2011, 13:47
  2. headlight switch window switch in blue
    By delboy2028 in forum Parts for sale
    Last Post: 26th May 2010, 08:56
  3. Headlight switch
    By Steven T Davies-Moss in forum Parts for sale
    Last Post: 1st April 2009, 13:18
