Thanks Thanks:  1
Page 8 of 8 FirstFirst ... 678
Results 71 to 77 of 77
Thread: v6 info that might help
  1. #71
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by ozdil View Post
    what is the name of that green-white part just next to number 8 ? or part number of it? mine has been broken. from two ends where black rubber hose connect to it?
    Just a a one way valve I think but don't have any other details sorry
    perhaps a dedicated thread asking someone may know
    Adam
  2. #72
    Jun 2015
    Riga
    8 Post(s)
    Trim : Elite custom
    Engine : 3.0
    Mileage : 95kMiles
    Guys, can anyone point me where are the glow plug on theese engines?
  3. #73
    Mar 2015
    Bristol
    15 Post(s)
    Engine : 3.0 V6 CDTI
    Belive they are in the v by the injectors?
    Sent from my D6603 using Tapatalk
  4. #74
    Jun 2015
    Riga
    8 Post(s)
    Trim : Elite custom
    Engine : 3.0
    Mileage : 95kMiles
    @dave234 injector are under rocker covers. I cant see glow plugs inside v in any picture
  5. #75
    Mar 2015
    Bristol
    15 Post(s)
    I have reached my injectors by taking the plastic top off when I got an air lock. Look for something sticking out that had a electric connection going to it should be the same for each cylinder
  6. #76
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    I believe the glow plugs are in the top of the V, just above the inlet manifolds. I may be wrong on that but I think I can remember seeing them when I did the SCVs and thinking it could be a pain to do them.
  7. #77
    Jun 2015
    Riga
    8 Post(s)
    Trim : Elite custom
    Engine : 3.0
    Mileage : 95kMiles
    https://www.youtube.com/watch?v=-H6XOkC652Y
    SCV Change VideoGuide(In polish, bet anyway)
  1. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  2. Hi all, new and looking for info - 2.0T!
    By hog in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2012, 22:55
  3. VXR info
    By big peachy in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2009, 14:50
  4. just after some info
    By pricey797 in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2009, 22:03
  5. 2.0T Info
    By Steven in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2007, 15:39
https:www.vectra-c.comforumshowthread.php150500-v6-info-that-might-helppage5
EGR Y30DT
z30dt engine
z30dt glowplug removal
z30dt cylinder numbers
z30dt throttle inlet manifold nm
y30dt head gaskets
vectra c 3.0 cdti thermostat
p0235 vauxhall signum
97353014
vectra c 3.0 z30dt glow plug ch
fehlercode p0016 opel y30dt
z30dt compression
Opel DTC P0093-52
thermostat opel vectra 3.0 cdti
head nm z30dt
y30dt head bolts nm
p9x engine
harness af23-533-5
y30dt engine weight
z30dt coolant pressure
how can i remove fuel regulator control valve on a vectra sri v6 3.0cdti
błąd p1294 3.0 cdti
vauxhall vectra c common rail
