Thanks Thanks:  1
Page 4 of 8 FirstFirst ... 23456 ... LastLast
Results 31 to 40 of 77
Thread: v6 info that might help
  1. #31
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    15 Post(s)
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Specifications
    Engine Y 30 DT
    No. of cylinders/ layout
    6 / V-type
    No. of valves
    24
    Capacity
    cm3
    2958
    Bore diameter
    mm
    87.5
    Stroke
    mm
    82
    Power output
    kW / rpm
    130 / 4000
    torque
    Nm / rpm
    Automatic transmission
    Manual transmission
    330
    370
    1600 - 3600
    1900 - 2800
    Compression
    18.5 : 1
    Exhaust emissions standard
    Euro 3
    Turbocharger
    717410-5 Garrett Turbo Inc.
    Engine Y 30 DT
    Idle speed
    with manual transmission
    Nm / rpm
    670
    with automatic transmission
    Nm / rpm
    670
  2. #32
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Perhaps dodgy coolant sensor. Sending bad signal whilst it's still warming up.
    So car thinks its revving too much for cold engine am throws limp mode to protect engine? :-/
    I'll do a few tests over this weekend or next and see if I can spot anything that maybe of help to you.
  3. #33
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
  4. #34
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by omega63 View Post
    Engine Y 30 DT
    Idle speed
    Nm / rpm
    670
    Nm / rpm
    670
    Is that idle speed for definate mate? Mine idles at 795 ish :-/
  5. #35
    Quote Originally Posted by CritchvxD View Post
    With fault code P0109 ?
    Personally I think the harness is nearing the end of its life
    As above, it only happens once every six weeks, so as always I wait until such an issue becomes more permanent before investigating further as by then it is easier to diagnose
    It's been like this for about 18 months now, so once every six weeks is almost nothing (roughly every 5K miles)
  6. #36
    Yes, the 670 RPM looks correct
    At idle mine is slightly below 700 (at warm idle)
    From cold it is about 800, once it has warmed up it bounces up to 950, presumably the ECU sending some instructions for valves to close, then drops back down
    However, there should be a cold idle and warm idle speed
    In some engines it is a gradual reduction in revs, in the Y30DT it appears to be controlled electronically
  7. #37
    Jul 2010
    15 Post(s)
    Mileage : 126,000
    Recommended Torque Values
    Engine Y 30 DT
    Designation
    Nm
    Exhaust system to front exhaust pipe
    20
    Exhaust manifold to cylinder head
    521)
    Central exhaust elbow to cylinder block
    96
    Front of exhaust pipe to turbocharger
    20
    Exhaust gas recirculation valve (heat exchanger) to intake manifold
    21
    Exhaust gas recirculation valve to neck
    21
    Drain bolt, engine oil, to lower part of oil pan
    42
    Axle shaft to wheel hub
    1) 2)
    Drive disc to crankshaft
    1203)
    Receiver-dryer to radiator
    4
    Block screw connection - oil cooling line, automatic transmission, to cooler
    1.8
    Cover, engine vent - timing case to timing case
    10
    Cover, engine venting, cylinder block, to cylinder block (M6)
    10
    Cover, camshaft housing, cylindr-1-3-5 to camshaft housing, bearing cover number-4
    25
    Timing case cover to timing case
    25
    Torsional vibration damper to crankshaft
    235
    Throttle valve module to intake pipe
    24.7
    Lower part of intake manifold to cylinder head
    31
    Injection lines to injectors and fuel distributor pipe
    30
    Control arm guide joint to steering knuckle
    30 Nm + 60° + 15°1) 3)
    Alternator to upper bracket, lower bracket (M8)
    28
    Transmission to oil pan upper section (M10)
    40
    Transmission to cylinder block (M12)
    60
    Compressor bracket to oil pan upper section, cylinder block
    50
    Bracket, injection line, cylinder-6 to intake manifold-2-4-6
    21
    Upper alternator bracket to timing case
    28
    Lower alternator bracket to timing case, cylinder block (M10)
    50
    Injector bracket to bolt (M10)
    30
    Injector bracket to bolt (M6)
    5
    Fuel lines bracket to upper timing case (M6)
    10
    Fuel lines bracket to upper timing case (M8)
    25
    Fuel return bracket to intake manifold-1-3-5
    21
    Rear engine damping block bracket to transmission
    80
    Rear engine damping block bracket to rear engine damping block
    80
    Left bracket, engine damping block, to transmission
    55
    Fuel temperature sensor bracket to camshaft housing-1-3-5 (banjo bolt)
    16
    Turbocharger bracket to turbocharger (M8)
    21
    Bracket for interim shaft to cylinder block, upper part of oil pan
    55
    Main bearing bridge to cylinder block, main bearing cover
    see operation "Crankshaft, Remove and Install" [IMG]file:///C:/PROGRAM%20FILES/cosids/DATA/TMP/LUREF_1.gif[/IMG]
    Main bearing cover to cylinder block
    Heat shields
    21
    High pressure pump to cylinder block
    21
    Crankshaft pulse pickup to timing case
    6.4
    Refrigerant line to receiver-dryer
    20
    Refrigerant line to block connector (separation point)
    20
    Refrigerant line to compressor
    20
    Ribbed V-belt tensioning device to timing case and cover of timing case (M8)
    25
    Ribbed V-belt, idler roll, alternator, at timing case (M10)
    50
    Fuel return line to high pressure pump (nut)
    25
    Fuel return line to fuel pressure regulator - distributor pipe (banjo bolt)
    20
    Fuel return line - high pressure pump to intake manifold-2-4-6 (bolt M8)
    25
    Fuel return line - leaked oil to intake manifold-1-3-5 (bolt M6)
    10
    Fuel return line - leaked oil to intake manifold-1-3-5 (bolt M8)
    21
    Fuel manifold to intake manifold
    21
    Fuel supply line to high pressure pump (nut)
    25
    Fuel supply line - high pressure pump to adapter, intake manifold-1-3-5
    35
    Lower radiator bracket to front axle body
    35
    Turbocharger coolant flange to turbocharger
    9
    Coolant pump to cylinder block
    11
    Radiator coolant pipe to cylinder head-1-3-5 (M6)
    10
    Radiator coolant pipe to cylinder head-1-3-5 (M10)
    50
    Coolant pipe, coolant compensation tank, to bolt (nut M8)
    10
    Coolant pipe, coolant compensation tank to front upper coolant pipe (bolt M6)
    10
    Front upper coolant pipe to bracket (M8)
    25
    Front upper coolant pipe to coolant pipe, cylinder heads (M6)
    10
    Coolant pipe, heat exchanger, to cylinder block
    25
    Coolant return line, turbocharger, to turbocharger
    34
    Coolant connections to thermostat housing / oil filter housing
    25
    Connecting pipe for coolant from cylinder block to coolant supply for heat exchanger
    10
    Coolant distribution piece to cylinder block
    10
    Coolant supply line, turbocharger, to coolant pipe, cylinder heads
    34
    Coolant supply line, turbocharger, to turbocharger
    34
    Intercooler to radiator
    4
    Lower charge air pipe to fan housing
    5
    Bearing cover, camshaft to camshaft housing
    22
    Bearing cover, camshaft intake, cylinder-2-4-6 (bearing number 5), to camshaft housing
    12
    Leaked oil line to injector (M10)
    20
    Leaked oil line to camshaft housing, cylinder-1-3-5 (M10)
    16
    Leaked oil line to camshaft housing, cylinder-2-4-6 (M10)
    20
    Leaked oil line to cylinder head-2-4-6 (banjo bolt)
    20
    Fan housing to radiator
    4
    Engine vent diaphragm to timing case
    4
    Rear engine damping block to front axle body
    60
    Left engine damping block to bracket, left engine damping block
    55
    Left engine damping block to body side member (M8)
    20
    Right engine damping block to body
    55
    Right engine damping block to right engine bracket
    55
    Front engine damping block to transmission
    80
    Front engine damping block to front axle body
    80
    Right engine bracket to timing case (M10)
    40 Nm + 90°
    Right engine bracket to timing case (M12)
    64
    Right engine transport shackle (timing side) (M10) to timing case
    50
    Engine transport shackle, cylinder-1-3-5 (RH) (M8) to cylinder head
    24.7
    Engine transport shackle, cylinder-2-4-6 (LH) (M8) to cylinder head
    24.7
    Camshaft housing to cylinder head
    see operations "Both Cylinder Heads, Remove and Install"[IMG]file:///C:/PROGRAM%20FILES/cosids/DATA/TMP/LUREF_1.gif[/IMG] or "Repair Engine Using a Part Engine"[IMG]file:///C:/PROGRAM%20FILES/cosids/DATA/TMP/LUREF_1.gif[/IMG]
    Camshaft bearing cover to camshaft housing
    22
    Camshaft sprocket to camshaft
    120
    Oil drain bolt to lower part of oil sump
    42
    Oil filter housing/heat exchanger (thermostat housing) to cylinder block (M8)
    25
    Oil dipstick guide tube to engine transport shackle, cylinder-2-4-6
    10
    Oil pump to cylinder block (M6)
    10
    Turbocharger oil return line to turbocharger
    21
    Turbocharger oil return line to cylinder block
    24
    Oil spray nozzles to cylinder block
    21
    Turbocharger oil feed line to turbocharger
    24
    Top of oil pan to cylinder block, timing case
    25
    Bottom of oil pan to top of oil pan
    9
    Pedal sensor to bulkhead
    9
    Swing arm to spring strut
    651)
    Con-rod bearing cap to con-rod
    see operation "One Con-Rod Bearing, Replace" [IMG]file:///C:/PROGRAM%20FILES/cosids/DATA/TMP/LUREF_1.gif[/IMG]
    Wheel to wheel hub
    110
    Intake pipe to intake manifold
    21
    Hose clamps of the air intake and charge air hoses (width 9 mm)
    3.5
    Hose clamps of the charge air hoses (width 12 mm)
    5
    Flywheel to crankshaft
    1453)
    Sensor - dynamic oil level check to oil pan upper part
    10
    Fuel temperature sensor to bracket
    23
    Coolant temperature sensor to coolant pipe, cylinder heads
    23
    Charge pressure sensor to intake manifold 1-3-5
    4
    Charge pressure sensor to intake pipe
    14
    Camshaft sensor to camshaft sprocket housing-2-4-6
    6
    Tie rod to steering knuckle
    351)
    Starter to cylinder block (M10)
    64
    Timing case to cylinder block
    25
    Spur gears
    35
    Catalytic converter support to front exhaust pipe (catalytic converter)
    25
    Catalytic converter support to top of oil pan
    28
    Turbocharger to centre of exhaust manifold
    21
    Deflecting elbow to exhaust manifold
    64
    Deflecting elbow to centre of exhaust manifold
    64
    Ribbed V-belt guide roller to support
    50
    Vacuum pump to camshaft housing, cylinder-2-4-6 (M8)
    17
    Compressor to compressor support
    22
    Condenser to intercooler
    4
    Supply unit (electro-hydraulic steering) to body
    22
    Reinforcement plate to body (M10)
    55 Nm + 45° + 15°3)
    Reinforcement plate to body (M12)
    90 Nm + 45 ° + 15°3)
    Front of front axle body to body (M12)
    80 Nm + 120 ° + 15 °3)
    Rear of front axle body to body (M12)
    100 Nm + 90° + 15°3)
    Heat exchanger to oil filter housing/thermostat housing
    39
    Upper toothed belt cover to timing case
    25
    Toothed belt drive wheel to high pressure pump
    160
    Toothed belt tensioning roller to timing case
    43
    Toothed belt, upper idling roller, to timing case (M10)
    50
    Toothed belt, lower idling roller, to timing case (M10)
    50
    Additional pump to radiator
    4
    Intermediate shaft to steering gear
    22
    Intermediate shaft to intermediate shaft bracket
    18
    Cylinder head to cylinder block(short bolts)
    39 Nm + 110° + 110°3)
    Cylinder head to cylinder block (long bolt)
    39 Nm + 130° + 130°3)
    Cylinder head bolt to camshaft housing (M6)
    9
    1) Use new fastening nut(s)
    2) Tighten axle shaft nut to 150 Nm. Then release axle shaft nut by 45° and retighten to 250 Nm.
    3) Use new fastening bolt(s)
  8. #38
    Jul 2010
    15 Post(s)
    Mileage : 126,000
    These figures are from Vauxhalls, TIS 2000, i think mines about the same as yours 795 ish, mines auto/tiptronic...
  9. #39
    Jul 2010
    15 Post(s)
    Mileage : 126,000
    Field Remedy: 1957
    Subject:Engine Y30DT, High Pressure Pump - Lack of power during accelerationModels:Engines:Option:Vectra-C 2003...2007,Signum 2003...2007Y30DT| Z30DT,Y30DT| Z30DTComplaint:Engine lack of power during acceleration. During investigation with TECH2 a pressure drop between actual rail pressure and desired rail pressure is visible.Cause:Blocked suction control valve (SCV) within the high pressure pump.Production:Modified production process (earlier changing of manufacturing tools, improved cleanliness) implemented at supplier. Countermeasures were implemented with engine number 69692 (01.09.2006).
    Remedy:
    Before carrying out Technical Service Bulletin 1957 update ECU with modified software as of TIS 2000-DVD, version 76 (a modified software regarding high pressure diagnosis was implemented, improved DTC: P0093 detection).If the DTC still occurs refer to the following snapshots in datalist 2 "NOK I".The snapshot shows an increased fuel flow restriction within the fuel feed circuit. 1: desired fuel pressure2: actuel fuel pressureWe recommend to disconnect the fuel lines from the tank to the filter, blow them by compressed air (in disconnected condition) and finally to replace the fuel filter assembly.
    The snapshot in datalist 2 "NOK II" shows a constant drop of actual fuel pressure and identified the suction control valves (SCV) failure. 1: desired fuel pressure2: actuel fuel pressure
    In case of an identified suction control valves (SCV) failure replace both suction control valves (SCV) of the high pressure pump as discribed below. Important: - During the complete procedure it is obligated to work in a clean environment. - Prevent contamination at SCV area. Small contaminations, which cannot be seen by eye, can cause major problems on engine performance. Particle size of 0,3 mm, can be already critical! - Do not use gloves. - Do not use SCV in case it has been dropped. - Make sure that pressure in the system is released before loosening the pressure connection pipe between pump and rail. - Disconnect battery after failure checking procedure. Wait for a few minutes before starting SCV replacement procedure in order to prevent any system action.Working Procedure:
    1. Remove high pressure pump - see working procedure "Replace high pressure pump", group "J", Service-Instruction Vectra-C/Signum. (Document-Number 01201498) 2. Seal junctions of high pressure pump (Picture I) - attach plastic cap (5) to high pressure junction - attach 2x paper collar (3) with 4x seal ring (1, 4) and cap nuts (2) to fuel feed junction and fuel return junction Note: All junctions of high pressure pump should be closed right after removing each fuel line from still installed high pressure pump.
    3. Clean high pressure pump. Note: Brush off all dirt and rust using wire brush. Spray off dirt and rust using parts cleaner. Important: The area around the suction control valves has to be cleaned very thoroughly! 4. Loosen suction control valve (1, Picture II) - remove 2x screw (2)
    5. Remove suction control valve (Picture III) - rotate suction control valve (1) to remove it from high pressure pump Note: Keep work area clean and make sure no contamination gets into and around suction control valve mounting hole.
    6. Prepare new suction control valve (Picture IV) - apply clean engine oil to both o-rings (1) of suction control valve
    7. Insert suction control valve (Picture V) - push suction control valve (1) into pump housing in direction of arrow using both hands
    Note: Several mm clearance (1) between suction control valve flange and pump head will remain. (Picture VI)
    8. Attach suction control valve - Install 2x screw by hand - tighten 2x screw with tool until suction control valve flushes with high pressure pump Note: Tighten each bolt alternately to prevent suction control valve inclination. - tighten 1st screw 13 Nm - tighten 2nd screw 13 Nm - re-tighten 1st screw 13 Nm9. Replace 2nd suction control valve accordingly.10. Remove seals from junctions of high pressure pump - remove plastic cap from high pressure junction - remove 2x paper collar with old seal rings and cap nuts from fuel feed junction and fuel return junction11. Install high pressure pump - see working procedure "Replace high pressure pump", group "J", Service-Instruction Vectra-C/Signum. (Document-Number 01201498)12. Conduct performance and leakage check - Conduct High pressure test by following TIS 2000 steps - Checking procedure (Tech2) - Non Guided Electronic System Diagnosis - B: Functional Group Test - B-004: ACTUATOR TEST - T-008: (for Z30DT T-009) Tester Display Fuel Leakage TestSpare-Parts: Part-No.: Catalogue-No.:Kit-suction control valve 98086740 8 19 348Labour Times: TC: Hours:U3 195 70 Install Kit-suction 92 5.9 control valveThe costs for this repair will be covered during the normal warranty.The regular warranty procedure should be used for claiming Set-up-time.FunctionalGroup:J - EngineComplaint Group:13 - No/Poor Function,20 - Poor PerformanceTrouble Code:None
  10. #40
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Mines a manual, it's done 120k tho so ya can't expect everything to be factory perfect lol.
    But I'm pretty positive even on my diagnostics it says idle should be 790 :-/
  1. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  2. Hi all, new and looking for info - 2.0T!
    By hog in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2012, 22:55
  3. VXR info
    By big peachy in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2009, 14:50
  4. just after some info
    By pricey797 in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2009, 22:03
  5. 2.0T Info
    By Steven in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2007, 15:39
https:www.vectra-c.comforumshowthread.php150500-v6-info-that-might-helppage5
EGR Y30DT
z30dt engine
z30dt glowplug removal
z30dt cylinder numbers
z30dt throttle inlet manifold nm
y30dt head gaskets
vectra c 3.0 cdti thermostat
p0235 vauxhall signum
97353014
vectra c 3.0 z30dt glow plug ch
fehlercode p0016 opel y30dt
z30dt compression
Opel DTC P0093-52
thermostat opel vectra 3.0 cdti
head nm z30dt
y30dt head bolts nm
p9x engine
harness af23-533-5
y30dt engine weight
z30dt coolant pressure
how can i remove fuel regulator control valve on a vectra sri v6 3.0cdti
błąd p1294 3.0 cdti
vauxhall vectra c common rail
