Thanks Thanks:  1
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 77
Thread: v6 info that might help
  1. #11
    wirral
    61 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    y30dt engine layout
    1- Brake fluid
    2- Coolant expansion bottle
    3- Fuel filter housing
    4- Cam position sensor
    5- Egr valve( tucked under the ecu mounted on bracket)
    6- Injectors
    7- Throttle body
    8- Turbo actuator
    will label more parts as i go through each picture to allow people to be able to see parts easier
  2. #12
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    after removing various electrical connections and vacuum pipes you can remove the upper manifold and reveal this
    1- Slightly better view of egr vlave
    2- MAP sensor (manifold pressure sensor)
    3- Common rail
    4- Pressure refielf valve for common rail
    5- High pressure fuel lines
    6- Tucked away down in the gap is glow plugs
  3. #13
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    cambelt layout for anybody thinking of tacking this job.
    very very easy cambelt, first one ive done on my own. no special tools are required.
    i would say as a job on its own about 2 hours start to finish if you where taking your time.
  4. #14
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Hey mate, can you check the numbers on injector plugs? 2 and 4 have 13 written on them...what about the other 4 jets?
  5. #15
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    1- just showing the location of the fuel injection pump, obvisously their would be that front head in the way but just gives an idea how deep down it is, thats why such a big job to do the dreaded SCV's which i wish i need about whilst having the car stripped so much, so im just hoping they dont go lol
    2- is the coolant temperature sensor.
    you can just about see it when everything is in the way just behind the inlet pipe to the turbo
  6. #16
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by Celes View Post
    sorry mate not with it, atm go mrs going mad about decorating and my mate on the phone asking baout his headgasket heads up me bumlol
    do you mean the number actually stamped into the injectors themselves?
  7. #17
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    a pic showing the thermostat.
    once everything is in the way and built up, you cant really see it, you can just about see it from underneith, changing that wont be so easy i cant imagin
  8. #18
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    one showing what looks like with rocker cover removed.
    this is the view for checkoing valve clearances. proably looking at around 30-45 mins of undoing things to get hear from opening the bonnet.
    the inlet cam is the one towards centre
  9. #19
    wirral
    61 Post(s)
    Trim : Basic
    Engine : 1.9
    just been out and hipped plastic cover off to check mate, and yeah all have 13 on them aswel as the letter H hope that helps
  10. #20
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    How long before Admin get back to me re. the sub forum .
  1. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  2. Hi all, new and looking for info - 2.0T!
    By hog in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2012, 22:55
  3. VXR info
    By big peachy in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2009, 14:50
  4. just after some info
    By pricey797 in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2009, 22:03
  5. 2.0T Info
    By Steven in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2007, 15:39
https:www.vectra-c.comforumshowthread.php150500-v6-info-that-might-helppage5
EGR Y30DT
z30dt engine
z30dt glowplug removal
z30dt cylinder numbers
z30dt throttle inlet manifold nm
y30dt head gaskets
vectra c 3.0 cdti thermostat
p0235 vauxhall signum
97353014
vectra c 3.0 z30dt glow plug ch
fehlercode p0016 opel y30dt
z30dt compression
Opel DTC P0093-52
thermostat opel vectra 3.0 cdti
head nm z30dt
y30dt head bolts nm
p9x engine
harness af23-533-5
y30dt engine weight
z30dt coolant pressure
how can i remove fuel regulator control valve on a vectra sri v6 3.0cdti
błąd p1294 3.0 cdti
vauxhall vectra c common rail
