Page 1 of 8 123 ... LastLast
Results 1 to 10 of 77
Thread: v6 info that might help
    wirral
    33 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Default v6 info that might help
    As we all know there is very limited info available on this engine, and has been discussed over past few days about having info available on this engine, so ive decided to start compiling a list of info, I will include as many pictures as I can, these will be from my own personal car (y30dt) from when I changed head gasket, so any body with the z30 please add your pictures, as I believe the engine is ever so slightly different.
    3.o v6 (y30dt) info 2002-2005
    No of cylinders - 6 DOHC
    Capacity – 2958
    Compression ratio- 18,5
    Fuel system – make =denso
    Fuel system – type= 0100
    Injection system;
    Air metering – MASS
    Pump type – common rail
    Injection sequence – 1-4-2-5-3-6
    Oil temp- 80c
    Service checks and adjustments;
    Valve clearance inlet- 0.35-0.45mm cold
    Exhaust- 0.40mm cold
    Compression pressure -21.5-25.5 bar
    Oil pressure -1.5/750 bar/rpm
    Thermostat open – 82c
    Lubricants and capacities;
    Engine oil- 5w30 synthetic 7.2 litres (inc filter)
    Cooling system -8.3 litres
    Brake fluid- DOT 4 0.5 litres
    Automatic transmission – 3.0-3.5 litres
    Manual transmission- 2.4 litres
    Power steering fluid – pentosin CHF 202
    aux belt layout
    critch the manual transmission is 2.4 litres
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    sorry mate my bad ill correct that
    South east
    Here's my contribution, plus anyone know the Renault name for this engine?
    Attachment 48978
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    thats great pic mate, will really help people out, im just in middle of going through my millionas of pics to try and find the ones i need.
    m8internet will know the name
    South east
    Found out from Google that Renault call it the P9X and Isuzu call it the 6DE1
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Saab = D30BL
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Kool guys .
    All we need to do now is to get our own sub forum where we can keep all this info.
    I PM'd Admin last night and also the same to Duncan's personal PM. Let's wait and see what the response is.
    Hopefully and not lol.
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Z30dt 2005-2008
    Capacity – 2958
    Fuel system – type= DECD2
    Injection system;
    Air metering – MASS
    Pump assembly –HP2270L
    Injection sequence – 1-2-3-4-5-6
    IDLE SPEED-790
    Oil temp- 80c
    Exhaust-0.35- 0.45mm cold
    Engine oil- 5w30 synthetic 7.5 litres (inc filter)
    Manual transmission- 2.2 litres
    wirral
    33 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Z30dt 2005-2008
    Capacity 2958
    Fuel system make =denso
    Fuel system type= DECD2
    Injection system;
    Air metering MASS
    Pump assembly HP2270L
    Pump type common rail
    Injection sequence 1-2-3-4-5-6
    IDLE SPEED-790
    Oil temp- 80c
    Thermostat open 82c
    Automatic transmission 3.0-3.5 litres
    Power steering fluid pentosin CHF 202
  1. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  2. Hi all, new and looking for info - 2.0T!
    By hog in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2012, 22:55
  3. VXR info
    By big peachy in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2009, 14:50
  4. just after some info
    By pricey797 in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2009, 22:03
  5. 2.0T Info
    By Steven in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2007, 15:39
EGR Y30DT
fehlercode p0016 opel y30dt
vectra c 3.0 z30dt glow plug ch
97353014
p0235 vauxhall signum
y30dt head gaskets
z30dt throttle inlet manifold nm
how can i remove fuel regulator control valve on a vectra sri v6 3.0cdti
błąd p1294 3.0 cdti
opel z30dt fehlercode p0235
opel signum v6 3.0 diesel temperature problem
y30dt scv location
vectra 3.0 cdti temperature sensors
vectra 3.0 cdti ect sensor location
OPEL 8 50 033 PIPE EXHAUST GAS RECIRCULATION
y30dt firing order
y30dt cylinder layout
renault p9x firing order
renault scenic engine layout
https:www.vectra-c.comforumshowthread.php150500-v6-info-that-might-help
vauxhall vectra c common rail
opel v6 3.0 common rail
opel 3.0 cdti injector valve voltage
https:www.vectra-c.comforumshowthread.php150500-v6-info-that-might-helppage5
crankshaft sensor location y30 dt
