Thread: DMF query, rumble at idle and if clutch depressed
    Mar 2011
    Glasgow
    Default DMF query, rumble at idle and if clutch depressed
    I have had a strange rumble for about the last 6000 miles, its not too bad and i hear it mostly when I am inside the cabin, if i gently push the gear level forward (with clutch pedal up) this noise dissapears, if I let it drift back to neutral its back.
    anyway from what I know i suspect dmf failure, at first i thought it might be the bearing as I've had similar symptoms on a small hatchback many years ago,
    just realised these vectra c 1.9 cdti 120's 2007 facelift have dmf's
    anyone confirm how long this can last, ive heard they can last a good 20k miles prior to failure,
    im putting aside £500 for the parts, clutch, flywheel, bearing, and possibly clutch slave cylinder (not sure if I need to change this as I heard there were some dodgy ones fitted on some cars, not sure if this is true or not)
    then will be hammering the job the day the dmf fails
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    Might sound daft, but check your gearbox oil first. May be running low and causing your noise.
    Hopefully it'll just need a top up
    Regular Member Chuff's Avatar
    Sep 2011
    Oxfordshire for Pleasure, Berkshire for business
    if you leave a DMF to fail completely it can also take out your gearbox
    Regular Member Cyruskint's Avatar
    Jun 2009
    Dorset
    I read elsewhere that the V6 CDTi has a DMF.........can it be so?
    Mar 2011
    Glasgow
    What kind of oil is required. I've double checked the noise and it sounds almost bubbly if tjat makes any sense
    Jun 2006
    St. Helens,Merseyside
    SAE 75W-80 synthetic
    f17 = 1.6 liters
    f23 = 1.55 liters
    f35 = 1.9 liters
    f40 = 3.2 liters
    Jun 2006
    f17 = 1.6 liters
    f23 = 1.55 liters
    f35 = 1.9 liters
    f40 = 3.2 liters
    Regular Member chuckleuk's Avatar
    Jul 2010
    Swadlincote
    How and where do you check the gear box oil level and I have a 56plate 1.9 cdti 150 so what gear box would I have? I'm also getting exactly the same noise cheers Lee
  1. clutch noise when pedal depressed
    Last Post: 22nd October 2012, 23:19
  2. Grinding noise when clutch depressed
    By y2joeyb in forum Troubleshooting
    Last Post: 24th September 2012, 11:27
  3. clutch query
    By unreal_event_horizon in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2011, 13:57
  4. Idle when clutch down
    By babyseal in forum Engine & Drivetrain
    Last Post: 27th January 2010, 10:07
  5. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
