Thread: Shock Absorbers
    Jun 2009
    Middlesbrough
    Default Shock Absorbers
    Hi
    How can you tell if the shocks have gone, both front and rear on a 2003 SRi DTi.
    I had a precautionary on the MOT for a leaking front shock but the back suspension seems very hard, harder than normal.
    When the boot is loaded ( I had an engine in it last week!) the ride of the car is much better, a lot softer.
    The car has done 184,000 so maybe its time they had gone but I don't know.
    Any help or other threads would be grately appreciated.
    KIndest regards
    Paul
    swansea
    I read somewhere that the working life of shocks was about 36k.
    Jun 2009
    Middlesbrough
    I suppose it depends on how you drive the car, I drive like an old granny on dope so I would hope to get alot more than 39k out of my shocks.
    The TIS mentions ride heights but it makes no sense to me.
    I would say I couldnt get the width of my palm in the gap between tyre and wheel arch at the rear.
    Paul
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    The rear shocks are very easy to remove. 1top bolt and 1 bottom bolt.
    Remove it and you should be able to compress the shock by hand. If its seized you wont be able to compress it.
    Quote Originally Posted by paulmatty View Post
    All of mine have gone now, so here is how mine were diagnosed
    Rear
    Starts off with banging noises, no affect on performance and can remain like this for some time
    Drive over a speed bump that is across the entire carriageway
    The rear of the car will wobble left to right as the rear tyres return to the normal road surface
    Leave the car for on a dry surface and look for oil dropping from the rear of the car around the suspension, this will confirm the shock has reached the end of its life
    Front
    The first signs are excessive dirt sticking to the lower part of the strut
    Lift the plastic / rubber cover at the top
    The metal should be clean
    If there is any liquid it has failed
    This liquid will then run down the strut allowing dirt to collect on it
    I had this on the previous two MoT (June 2010 and June 2011), and it finally failed at the beginning of this month
    One thing to note is that ride height does fall very slightly, but it is so little you will hardly notice it
    It is very noticable when both the springs and shocks are replaced
    Many people think the wrong type of springs and shocks have been replaced, but it is just due to new parts (providing the correct parts have been fitted)
  1. New shock absorbers
    By Johnsdutton in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2009, 20:11
  2. New shock absorbers
    Last Post: 24th August 2009, 19:16
  3. shock absorbers Help!!
    By Niks in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2009, 12:41
  4. Shock Absorbers
    By GaryJ in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2007, 12:57
  5. Shock Absorbers
    By installer in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2005, 17:37
