Results 1 to 10 of 27
Thread: Scv guru's
    Aug 2009
    Ascot
    Default Scv guru's
    Car is in vauxhall today having them fitted, but got a phone call saying they need to replace Cambelt and all the high pressure fuel lines?!? They said its what the field remedy or there system says to do??? So now they want another £220
    I don't mind the Cambelt but don't get the fuel lines
    Nick
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Nick -can you ring them and get the field remedy number?
    Then me or others can ask around and see what comes up on TIS2000 .
    Aug 2009
    Ascot
    Quote Originally Posted by gtr1000 View Post
    Thanks mate, mark has checked that as its field remedy 1957And can not see any mention of fuel lines :-(
    Nick
    have printed it off for you nick ok
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Nick & Mark - as an aside, do you think I should start a thread asking who owns a Y or Z30DT? At least then we could compile a knowledge base and who know's, we could even ask Admin for our own section as this engine is sooo specific with no one knowing the ins and outs of it?
    Aug 2009
    Ascot
    Sounds good :-)
    Nick
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    5 Post(s)
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    When i was a Tech. for Vauxhall dealers here in Manchester, we would get the Vivaro vans in with complete failure of the diesel high pressure pump. We would find in the fuel filter housing a large deposit of metalic filings, this contamination would be throughout the entire diesel fuel system and we would have to change the fuel tank, fuel lines, filter and housing, pump, high pressure injector pipes, and in many cases the x4 diesel injectors. In your case they may have found some contamination in the fuel lines/pipes, in most cases we would be able to relevent information on these engines on TIS 2000....
    Aug 2009
    Ascot
    Quote Originally Posted by omega63 View Post
    Just wonder if I am having pants pulled down :-)
    As they rang me up to say I needed x, y &z parts so I queried them and he said I will ring you back as the technican has the info, he then said on his system it showed you had to change all the high pressure fuel lines, but know one on here has heard of that
    Nick
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Will need a belt because belt has to come off to remove pump.
    An they will be saying fuel pipes because your meant to change them once they've been off. But I refitted mine after doing head gasket an they've been fine.
    An tbh your probably better getting them to fit full timing kit not just the belt. As its tensioners/ rollers that fail unless of course it's been done recently.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
  1. any pc guru's out there?
    By tolly in forum General Chat
    Last Post: 18th July 2012, 21:12
  2. One for the Camera Guru's
    By spennny in forum The 'Off Topic' room
    Last Post: 31st July 2010, 11:39
  3. Any Camera Guru's
    Last Post: 21st July 2010, 17:14
  4. Calling all guru's
    By lizard in forum Suspension, Wheels & Brakes
    Last Post: 3rd January 2010, 22:24
  5. Guru's
    By spoons in forum The 'Off Topic' room
    Last Post: 21st June 2008, 16:19
