Thread: bugging me
    Jul 2011
    UK
    Year : 06
    Unhappy bugging me
    Car making clunk sound when brake at slow speed only does it now and then somtimes louder seems to be coming from the front
    wirral
    42 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Checked all the wheel nuts are tight?
    Has it got non genuine pads fitted?
    wirral
    42 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    wifes car was doing this, turned out to be a disc pad had come away from the metal backing and was floating backwards and fowards
    Jul 2011
    UK
    Year : 06
    The brake pad had came away that what ya saying as missis drives car up and down motorway everyday
    Wheel nuts are tight just had them off last week
    Jul 2011
    UK
    Year : 06
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 85000
    yes the friction material that the disc pad is made from and come off the metal backing plate so even though the brakes worked fine it clunked every time brakes were applied or the car went from fowards to reverse
    Jul 2011
    UK
    Year : 06
    Yer that's what happens so new pads job is it dangerous to drive
    Sep 2011
    Sipson
    Or look at the front wishbone bushes, mine went on my toledo and sounded like the brakes too, but it was the wishies rising up under load of brake, then releasing as car settled or moved forward. I was adamant it was my pads too as the wishies had only been done 6 months prior, but it seemed they either failed prematurely or the cheap set I got off Ebay were indeed "cheap".
    Regular Member Vectra Meldrew's Avatar
    Hertfordshire
    Sounds like the pads have just got a bit sticky at the points where they slide side to side in the pad carriers. Usually just a case of taking the pads out and cleaning the edges and maybe a tiny bit of copper grease on the contact points.
    It happens quite often on front or back but you might find pads need changing anyway.
  1. Completed a few things that were bugging me!
    By Maverick in forum Non Vectra C/Signum Album
    Last Post: 1st June 2012, 19:10
