Thread: air flow meter
    Feb 2011
    lincolnshire,sleaford
    Vehicle : Cdti
    Trim : Sri
    Engine : 1.9
    Default air flow meter
    had my 150 cdti serviced in sept this year and the mechanic said there was a air flow meter fault on his reader showing up ,although the car ran ok and it was avg 50 mpg ,over the past couple of months my mpg has dropped to 45/46 mpg keeping it to the speed limit could this be the air flow meter ?is that the box on the pipe that comes out of the airbox?
    West
    yes, it's just after the air box, do you have any warning lights
    Feb 2011
    Vehicle : Cdti
    Trim : Sri
    Engine : 1.9
    no warning lights but i asked the garage to turn my service light out and he told me that its not just the service light it could be a fault as well and it gave an air flow meter fault he didnt know if it was an old fault or a new one and told me to try it ,but im getting crap mpg now and thats driving it steady
    West
    was the light an oil can with spanner or a car with spanner, the mechanic could have cleared the fault & then done a new check for any present codes
    Feb 2011
    Vehicle : Cdti
    Trim : Sri
    Engine : 1.9
    oil can and spanner i think
    West
    I have never known this to indicate a fault... i'm pretty sure any maf faults would normally throw the car with spanner...
    maybe it's just time for some new oil & filters... along with some injector cleaner & a good thrash
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    car with spanner light will iluminate if its a maf problem, think its P0100 fault code.
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    I am not 100% sure, but I THINK it is possible to turn off Check Control using a code reader or tech 2.
    This MIGHT stop any faults appearing in the rev counter.
    It's certainly an option that can be seen in op-com.
    Perhaps you could attend a local meet and there is a good chance somebody there will have a code reader and will check for you.
    Short story.
    Before I changed my tid to a gid, and enabled the on-Board Computer (BC) I had lots of bulb failure warning in the small box in the rev counter.
    When I had the car serviced i asked about them and the guy said he checked them and had sorted it.
    No more Bulb warnings, not even when a bulb later failed??
    Next service, car returned, bulb warnings back!!
    Changed every bulb and cleaned contacts, etc., and got rid of fault eventually.
    With BC and Check Control, it tells you exactly which bulb, which is brilliant.
    HTH's
  1. air flow meter
    By bulldogblu in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 12:44
  2. Air flow meter ??
    By craig-k in forum Engine & Drivetrain
    Last Post: 12th July 2009, 17:11
  3. air flow meter
    By Morephun in forum Engine & Drivetrain
    Last Post: 13th October 2008, 19:42
