Results 1 to 10 of 25
Thread: What do I need to Fit a box.
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Default What do I need to Fit a box.
    In prep for the arrival of me box from Diagnostix, Can someone tell me what tools i need to get the engine cover off and how it's done? Want to make sure I've got the tools in work tomorrow for fitting!
    Bournemouth
    As long as you have a decent socket set you needn't worry, I'm no mechanic and I fitted mine in 15 mins... mainly cos the bolts were sunk low in their respective holes... worst bit was getting the airbox out... loads of clips! the last engine bay I worked in was a CRX.. very open and basic.. modern motors seem to be filled with plastic odds and sods.
    Still if i can do it, rest assured you'll breeze through it
    Feb 2006
    Wirral
    The airbox has gotta come out too?
    Is yours a 120 or a 150 matey?
    Feb 2006
    Wirral
    120 Alex
    Bournemouth
    Ah sorry no, it won't, it did with mine as I was fitting a K&N at the same time.... wot an eejit soz...
    Still makes it easier still for you.
    Feb 2006
    Wirral
    phew!
    Your engine has two screws holding it on matey.
    Once the engine cover is off you won't need any tools at all. The loom ECU removes from your Common Rail and attaches to one end of the tuning module. The other connector on the module plugs into your rail. Job done.
    I had a How2 somewhere but can't find it. I'll keep looking.
    Feb 2006
    Wirral
    Is that the one I read earlier that talked about cutting ECU wires?
    No!!!!!!!!!!!!!!!!!!!!!
    No cutting involved. Plug and play on the CDTi's
