Thread: 2.2 DTI engine temperature
    Default 2.2 DTI engine temperature
    What temperature should the temperature gauge read when at normal running temperature? Mine reads 85*C and takes ages to warm up in this colder weather. Suspect it needs a new thermostat but don't want to replace it and it make no difference. Dealer says the thermostat is 92*C which would mean the needle in the middle which i would expect. Car runs ok and has been like it since i bought the car 4 years ago.
    Jan 2008
    Lucenec - Slovakia
    I think this is absolutely normal... Unfortunately yes, it takes ages to this engine to warm up when interior heating is on. My experience is, when interior heating is on and outdoor temperature is for example -10 it takes nearly 20 kms (!!) for motor to warm up... but when heating is off it takes only approx. 4-5 kms !!! - and after then I switch on the heating... buuut a 12V heated seat cover is a "must have" for this "operation".
    Sep 2011
    Sipson
    sounds normal, mine can take a good 5 miles, but also depends I think if you are in free moving traffic or putting along at 5mph.
    Mine tends to sit between 85-88 when at speed, but sitting in traffic it gets as high as 97C before the fan kicks in.
    I also torque app for my phone and get live readings from the ECU, which correlates with the temp gauge, so I wouldn't worry.
    Thanks for the feed back, ill spend my money on a warmer coat then instead of a thermostat
    Jan 2008
    Lucenec - Slovakia
    Hello guys! Well, yesterday I've installed this engine preheater and I have to say it's worth it, especially in morning on cold start -- oops there is no cold start! It keeps your engine temperature between 50-60 (there is a built-in thermostat in the preheater). You can also switch on the interior heating but make sure you have your accumulator in good condition... mine is a 85Ah Varta Silver, 4 years old but still without issues... I used to switch on the fan-heating (with ignition on of course) but "only" for 10-15 mins but its enough to heat up the interior...
    Pictures taken today morning
    The preheater:
    Forgot to set up the clock
    london
    Quote Originally Posted by Alistair123 View Post
    £10 for the thermostat. Blank off three of the bumper grills with plastic card and fix with cable ties.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Mine runs at about 85-86 in this weather, and about 89-90 in the summer.
    Takes about 5-6 miles to reach full temperature.
    Stat opens at 92 degrees.
    HTH
  1. Engine temperature up and down
    By benwalters82 in forum Engine & Drivetrain
    Last Post: 7th March 2013, 21:01
  2. Engine Temperature keeps going up and down (2.0 DTi)
    By Whosane in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2013, 00:29
  3. Engine temperature
    By NI-2.2SRI in forum Engine & Drivetrain
    Last Post: 2nd February 2009, 11:40
  4. Engine Temperature
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2006, 22:30
  5. Engine temperature
    By 2ltrT in forum Engine & Drivetrain
    Last Post: 25th July 2005, 16:10
Normal working temperature for vectra c 2.0 dti
ideal running remp for vauxhall vevtra 2.2
what temperature does the preheaters come on vectra c
2.2 vectra c temperature
