Thread: EGR Blanking help/advice
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    Default EGR Blanking help/advice
    Hi peeps,
    Ive just blanked off my egr (1.9cdti 150)
    The car with spanner light has come.
    Is this supposed to come on? i thought it was the little eml light in the bottom right hand corner that was only supposed to come on.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Are the Electixal connectors defiantly connected?
    Sep 2009
    swansea
    Trim : Club
    yep. by that u mean the electrical connector to the egr?
    i didnt even take the egr off. i just undone the 2 x intake pipe bolts & just loosened off the other bolts to reallign the egr with the intake pipe.
    cars running fine & alot better. turbo spools up sooner & the lumpyness has gone on tick over
    Im not getting the small eml light just the big one (car with spanner)
    has amyone else had this?
    i was on the assumption only the little light should come on
    Sep 2009
    swansea
    Trim : Club
    Bump :-)
    Sep 2009
    swansea
    Trim : Club
    just took it out for another spin & the car/spanner light went off & the little light illuminated.
    just getting the car/spanner light on egnition start now.
    im hoping thatl be a stored fault code & will cure itself in a couple of weeks.
    But overall im happy
    as its not cost efective to pay to have the egr removed from the ecu i WILL be getting remap as some point early next year
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Just to confirm, this is what happens, you get the spanner light first, then the emissions light comes on and stays on (unless mapped out).
    Regular Member Bullylad's Avatar
    Bolton
    Driving home tonight got a few seconds of reduced power and the car and spanner light came on for a mament.
    I had this a few years ago and VX sorted it out under warranty
    This time I am going to blank off the EGR valve as it seems easy enough to do but what I want to know is this.
    Does any part of the EGR need cleaning before I fit the blanking plate?
    Thanks in advance!
    north east
    Quote Originally Posted by Bullylad View Post
    Thanks in advance!
    I fully cleaned mine before blanking off on the theory if I wanted to unblank it I wanted it to not seize up, anyway blanked it off with a full blanking plate 1500 ish miles ago and never got teh car and spanner or emissions light on.
    chesire
    i blanked mine about 3000 miles ago and never had any problems with it except the spanner light ! you get used to ignoring it and it certainly ran a lot better
    scotland
    Quote Originally Posted by supersteve_75 View Post
    Easy enough to pop the dash pod out and put a bit of black tape over that annoying little light I found
  1. Egr blanking
    By 1 hammer in forum Diesel Engine related
    Last Post: 24th November 2012, 19:40
  2. EGR blanking
    By MattDC in forum Diesel Engine related
    Last Post: 15th March 2012, 10:19
  3. egr blanking
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2011, 15:16
  4. EGR blanking
    By ctj in forum Engine & Drivetrain
    Last Post: 1st January 2011, 02:17
  5. egr blanking
    By tugger434 in forum Vectra C / Signum Car Chat
    Last Post: 19th September 2010, 13:04
