Results 1 to 3 of 3
Thread: help needed please
    Nov 2011
    glasgow
    Default help needed please
    signum 04 plate 2.2 direct non starting ...changed high presure pump fuel regulator preasure sencor crankshaft sensor spark plugs still not firing had diagnostic done no faults showing ive heard that somtimes vauxhall change fuel rail sorry also changed throtile body nightmare goes on any sudjestions gets a spark ok unsure if second hand high preasure pump was ok
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Are you actually getting fuel upto to injectors?
    If not are you getting in from tank to pump?
    Nov 2011
    glasgow
    yes tank is firing out fuel got another diagnostic done but fuel preasure is only 3265 so buying a new high preasure pump incase the second had one was faulty 2 realy dont want to give up on this car
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
