Results 1 to 10 of 11
Thread: Outside temp
    Regular Member blackbeauty's Avatar
    Feb 2007
    Benfleet, essex
    Default Outside temp
    I am after the wire and sensor which tells you the temperature outside. Found this on eBay item 230701465459, is this what I need and if so where do I get the wire for it
    Full Member plasma's Avatar
    On the Forum
    346 Post(s)
    Engine : 150
    Mileage : 74000
    Couldnt use your old one?
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    The sensor and wiring should already be fitted as standard to your car, behind the front bumper.
    The sensors are quite universal across the vauxhall range.
    Regarding wiring, if you are looking for original coloured wiring and the connector, then you could easily get these from any Vauxhall in the scrap yard.
    It is a standard wire pair of Blue and blue with a white stripe.
    I know for a fact, that the sensor is the same for Cav mk3, Vectra-B, Vectra-C and Omega-B
    Feb 2007
    Benfleet, essex
    Would one from an omega fit. Found this on eBay 20 quid though
    220884258862
    Feb 2007
    Benfleet, essex
    220884258862
    Engine : 1.9 CDTi
    I have one from my Signum you can have for £5 delivered
    Feb 2007
    Benfleet, essex
    Does that include the wire ??
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by blackbeauty View Post
    220884258862
    As said in my post, yes Omega-B parts will fit.
    I am assuming that you have got a car without the front bumper, or the front plug has been cut off after a front end smash.
    Otherwise this would be fitted as a standard part.
    Are you wiring all the way upto the module?
    If so, the wiring is something like..
    Sensor - blue/white wire to Body control module pin 44
    Sensor blue wire to body control module pin 47
    The Body control module is up to the side of the glove-box on the inner wing on the passenger side of the car. (UK right hand drive vehicles)
    There should be a big-ish connector behind the bumper, strapped to the metalwork, down below the headlamp assembly / radiator grille.
    It should have about 8 or 10 pins in it..
    only 2 or 6 should be populated.
    Two are for the Temperature sensor,
    and the remaining 4 wires (I think), are for the front fog-lights - where fitted.
    Hopefully you can connect up to here.
    Feb 2007
    Benfleet, essex
    Cheers Robsey,
    Im not great with electrics, Il have to check what is there, I just thought I would buy one and fit a whole new thing.
    tomorrow il check the module now that I know where it is and see whats left of the cable if anything.
    Lee if yours has a wire il take it.
    Many thanks
    Engine : 1.9 CDTi
    Is just the sensor.
    The wire is part of the bumper loom.
  1. temp
    By HARRY SRI in forum Engine & Drivetrain
    Last Post: 19th January 2013, 19:44
  2. What's your temp at?
    By MickAP in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2011, 22:14
  3. What temp should air con be ?
    By bighammerfan in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2010, 17:49
  4. DTI temp
    Last Post: 23rd September 2010, 22:53
  5. outside air temp
    By leeashford in forum Electrical & ICE (including SatNav)
    Last Post: 13th January 2010, 19:34
