Thread: adapters?
    Nov 2011
    cornwall
    Default adapters?
    Hello,
    I have a set of bbs lm alloys in 19: they are 5x112 and the vectra is 5 x 100 does anyone know anyone that can make adapters to get them to fit ??
    Ray
    Regular Member 4ndy's Avatar
    Oct 2010
    Glasgow
    The Vectra has a PCD of 5 x 110, not 5 x 100.
    You can use wobble bolts that will allow adjustment of the PCD by 2mm in either direction. (5 x 108 or 5 x 112)
    Nov 2011
    cornwall
    ah sweet i have some wobble bolts awesome
    Oct 2010
    Glasgow
    You will just need to ensure the centre bore is the right size (or larger and use a spigot ring) and the offset is correct.
    Nov 2011
    cornwall
    yh i will check that dont surpose you know that info the vectra?
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Yep bore size is 65.1 mate pcd 5x110
    Oct 2010
    Glasgow
    The offset (stamped et on the inside of the wheel) should be between 35 and 45mm. Use a wheel offset calculator to compare the new wheels to what you already have.
    My current wheels as an example are 8" wide and have an offset of 42mm.
    I nearly bought a set of Brabus wheels that were 8½" wide with an offset of 32mm but they would have stuck out of the arches by an extra 16mm and further away from the suspension by 4mm.
  1. bulb adapters
    By andy_richmond in forum Electrical & ICE (including SatNav)
    Last Post: 30th September 2012, 14:32
  2. bulb adapters
    Last Post: 29th September 2012, 20:15
  3. Alloy Adapters?
    By weverall in forum Styling
    Last Post: 4th December 2011, 20:04
  4. hub adapters?
    By ballan22direct in forum Styling
    Last Post: 9th May 2010, 12:24
  5. PCD Adapters
    By Padster72 in forum Suspension, Wheels & Brakes
    Last Post: 4th April 2008, 08:18
