Thread: Tow Bar Electrics 7way bypass relay what colours
    Regular Member chuckleuk's Avatar
    Jul 2010
    Swadlincote
    Default Tow Bar Electrics 7way bypass relay what colours
    i will be installing a 7way bypass relay at the weekend can anybody help me with what colour wires in the rear light clusters control which light, car is a sri hatch facelift i know that the white and black is reverse and brown is the earth but need to know what colour for break light, indicator etc cheers Lee
    Attleborough
    Brake Light = Black/Yellow
    LH Side Light = Grey/Black
    RH Side Light = Grey/Red
    Fog Light = Black/Blue
    LH Indi = Black/White
    RH Indi = black/Green
    And ya Bypass colours are
    1. Yellow = Lh indi
    2. Blue = Fog
    3. White = Earth
    4. Green = Rh Indi
    5. Brown = Rh Side
    6. Red = Brake
    7. Black = Lh Side
    P.s. If ya using a smart 7 bypass then you shouldn't need to connect anything to the sidelight feeds of the car as the unit will detect the voltage differences from the brake feed wire and supply the outputs accordingly.
    Also depending where you connect at the rear, there is more than 1 black/yellow wire. One of which is for the filler flap lock!!!
    Jul 2010
    Swadlincote
    You are an absolute star thank you so much cheers Lee
    Attleborough
    Quote Originally Posted by chuckleuk View Post
    Thats ok mate no probs. Used to fit towbars and done hundreds of veccy's including mine. Give me a shout if ya wanna know anything else.
    Bucks
    Hi Johno8222
    This is perfect. I'm doing the job this weekend so you've just saved me lots of tracing wires through the boot!
    Any advice on where to bring the main cable for the 12n and 12s in from the outside - The instructions tell me where to drill for the actual towbar but not for the electrics!
    Ben
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The genuine vx towbar wiring comes through next to the number plate light wires....that's where i'd bring them in
  1. egr bypass thought
    By james walker in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2012, 12:17
  2. Vectra C towbar electrics/Relay wiring
    By canny03 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd March 2012, 01:31
  3. CanBus bypass
    By krisby in forum Electrical & ICE (including SatNav)
    Last Post: 12th October 2011, 08:58
  4. 150cdti EGR bypass.
    By mally in forum Diesel Engine related
    Last Post: 14th April 2011, 00:18
wiring diagram towing for 2007 vectra
vauxhall vectra c towbar wiring diagram
towbar wiring diagram vauxhall vectra
vauxhall vectra c towbar electrics
vauxhall signum cdti by pass relay
vauxhall omega towbar electrics
fit 12n wiring to vectra c
vauxhallvectra towbar electrics
opel vectra c 1.6 live power in boot for tow bypass relay
vauxhall vectra c towbar fitting instructions
vectra c towbar vauxhall bypass relay
vauxhall by pass relay
vectra 2007 towbar wiring diagram
vectra towbar wiring diagram
7 pin bypass relay wiring diagram vectra c
vectra 07 smart relay bypass
vectra c rear light wiring colours
vectra c towbar bypass relay
what colour is sidelight live on vectra c
vectra c colour towbar wire
