Thread: Change??
    Nov 2011
    cornwall
    Default Change??
    Hello,
    How easy is it to change from a half canbus to a full canbus this is mainly so i can see mpg its in a 2002 ls
    Ray
    Regular Member Das's Avatar
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    You just need to do the TID to GID upgrade. Theres a how2 for this and is pretty easy.
    Regular Member tonci26's Avatar
    Apr 2011
    belgrade
    Vehicle : vectra c gts
    Engine : 1.8 petrol and lpg
    Mileage : 169000 km
    questin for DasArab i also have a vec 2003 with half canbus. The only thing to se the mpg is to change the center display and of course the wipers lever?
    Nov 2011
    cornwall
    why the wiper lever ?
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    You may need to add the 2 extra wires to the OBD Plug under the ashtray, Im sorry I do not know what the 2 extra wires do, but Im sure I read that someone actually found they didnt have to add these wires to get it all to work. You also need a Tech2 or opcom session to active it. If you add the screen without the wiper stalk and activation all you will get is the Range left in the tank.
    Here
    35 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Quote Originally Posted by Ray_Ray280 View Post
    Wiper lever has the BC(board Computer) function control, allowing you to scroll through the menu and reset and accept things like bulb warning functions. Ray im sure someone has the full GID items required in the for sale section too.
    Ely, Cambridgeshire
    58 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Without the two extra wires, you can't program the GID
    Full Member coldo's Avatar
    Scotland
    I have been worndering about this. I didn't fit the two wires when I put my gid in yet it works fine with no issues. It's all controlled off the wiper stalk. What do you need to program to the GID that makes these wires nessesary?
    What I would say is swapping it (even though I had help) was dead easy... Swapping some wires in a plug, installing a stalk, op-com/tech2 to activate the stalk and a bit of faffing to get the wipper bottle working (which I ended up splicing and bypassuing as the connector was nackered).
    Im half can bus also...
    Pics of mine in place...
    The how to guide in the "guide" section is dead easy to follow... Just make sure you source the right parts and take it from there.
  1. Automatic Gearbox Oil - Change Or Not Change?
    By rocket999 in forum Engine & Drivetrain
    Last Post: 24th May 2013, 17:50
  2. Manifold change poll: Actuator change or not
    By hertscol in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2012, 18:52
  3. Oil Change
    Last Post: 22nd March 2012, 10:45
  4. Change Discs - Change pads?!?!
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 11th April 2010, 09:54
