Thread: arb upgrade
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    Default arb upgrade
    which vectras generally have the largest size of arb as im looking at what i can do handling wise for the vec and a thicker/stiffer anti roll bar sounds like a good idea, especially on the back, might try thickest pon the back and thinnest on the front to help turn in, if it turns out to be an ok job to change a bit of experimenting may be in order
    Regular Member Keif's Avatar
    In the Garage
    Thickest rear is 19mm, thinnest front is 24mm.
    As for what they come on, it's not listed that way on the EPC, but assume the Higher spec/larger engined cars have the 19mm rear and the lower spec/smaller engines have the smallest front.
    Part Numbers
    Front Anti Roll Bars
    24460828 - 24MM (IDENT AH)
    24421799 - 24.2MM (IDENT AD)
    24411075 - 25.2MM (IDENT AE)
    Rear Anti Roll Bars
    13131955 - 16mm
    24457381 - 17mm
    24457382 - 18mm
    24457383 - 19mm
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Mileage : 166000
    excellent mate, thanks, im planning on doing what you have just done on your car and give the suspension a once over as i wanna stop all the knocks and bangs and i wanna get it handling as good as i can and make it look nice
    trouble with changing the front anti roll bar is that you have to drop the subframe down to get at it
    wouldnt you be better just getting poly bushes and tightening it up like that
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Mileage : 166000
    fair enough i might just get the uprated bars so i can keep the front one handy for when i have to next drop the front frame, and im gonna put poly bushes on, a little project for the winter me thinks
  1. upgrade the 314mm to vxr set up or upgrade the rears?????
    By rob warrington in forum Handling & Braking
    Last Post: 24th September 2012, 09:26
  2. gid upgrade
    By booker413 in forum Vectra C / Signum Car Chat
    Last Post: 24th April 2010, 16:48
  3. Looking to upgrade
    By Mark2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 6th March 2010, 20:17
  4. upgrade on upgrade
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 23rd April 2009, 23:27
  5. upgrade done what next ?
    Last Post: 19th April 2009, 22:46
