Thread: blowing warm not hot
    wigan
    Question blowing warm not hot
    he out there my vectra is blowing warm air not hot i have flushed the system and just had my thurmo changed still same warm air. Dose anyone have any clue what is causing this read a thread about a pin coming off the heater flaps as any one seen this happen if so can you explain its doin my head in now HELP
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Take glove box out. An look towards centre colum should see a pink/ red lever see if moving that manually gives you hot air
    wigan
    hi thanks for reply i thought it was on drivers side no wonder i could not see out can you open this by hand.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Once glove box it out think it's 5 t25 torx bolts.
    That pulls out. An should the be able to see it then. Pop the rod towards the motor off an shud then be able to operate the flaps by hand
    wigan
    thanx for that i will try that i was lookin on the wrong side.
  1. Air con blowing out warm air
    By Baggers 2.0 in forum Vectra C / Signum Troubleshooting
    Last Post: 11th August 2012, 17:26
  2. Replies: 1
    Last Post: 28th September 2011, 21:57
  3. Vectra c heater prob only blowing warm help
    By 0114NIGEL0114 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd January 2011, 17:03
  4. blowing look warm air
    By keithv1 in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2010, 16:07
  5. heater blowing warm
    Last Post: 3rd December 2010, 17:09
