Results 1 to 3 of 3
Thread: CODES Help....
    Jul 2011
    belfast
    Default CODES Help....
    my vectra c 2.0 dti engine management light came on when i was driveing slow in second gear and when i sped up the light went off same thing happened in third gear but not in first , fourth or fifth gear. so i got it put on the computer n these codes came up:
    P1105 - BARRO METRIC PRESSURE NOT PLAUSIBLE WITH BOOST.
    P105
    Can anyone help me out on what is wrong with my car or what they mean?
    Nov 2010
    Plymouth
    I had a similar problem a few weeks back and read the same fault code.
    I believe that the Barometric pressure sensor measures the external air pressure as some kind of reference value for the boost pressure to be based upon. Knowing this....
    I removed the Barometric pressure sensor, cleaned the electrical contacts blew gently into the hole underneath to remove any loose debris (Scientific I know!). When fitted back it still gave the same fault.
    It then dawned on me the fault may lie with the boost sensor on the inlet manifold. Just removed it, cleaned VERY GENTLY with a small artist brush and some WD40, refitted it and no fault since and LOTS more power!
    West
    clean the boost sensor, carb cleaner is good along with a tooth brush
  1. help with these codes?
    By ben2996 in forum Troubleshooting
    Last Post: 19th February 2013, 23:56
  2. CODES,They come they go !
    By noudder72 in forum Engine & Drivetrain
    Last Post: 17th August 2011, 13:40
  3. What do these codes mean ??
    By bembo449 in forum Engine & Drivetrain
    Last Post: 22nd March 2011, 21:07
  4. Help with codes please..
    By frasedeb in forum Troubleshooting
    Last Post: 7th December 2010, 22:19
  5. can anyone help with these codes please
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 16th September 2009, 14:48
