Results 1 to 10 of 27
Thread: V6 CDTi information (or lack of it)!!!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default V6 CDTi information (or lack of it)!!!
    Let's face it, as I've found out recently, there's a lack of detailed info on the Y and Z30dt Isuzu engines - agreed?
    VX stealers don't know much about the engine or its associated faults/problems, all the overseas forums are in a foreign language, Haynes is no good, TIS2000 doesn't offer a solution and apart from Vec-C.com, there's not a lot of useful info out there.
    So what's the answer guys? What can us V6 oil burner owners do to make life easier, apart from buy a Veccy with a different engine?
    get the tools out and get stuck in !!!!
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by marktaylor View Post
    I do but's it's knowing where all the components are, how they're linked together, what values each component should exhibit as a datum, etc, etc..
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    You said it. Get a Vectra with a different engine.
    You will find nothing on these out there. I turned to www.motor-talk.de, learnt some german there, but like here, no one seems to know this engine well...apart from a user which I can't remember right now...
    My philosophy is drive it to destruction, then chuck it in the skip
    Someone else locally has disposed of theirs
    When I enquired further today they too reported the known splutter, coughing symptoms
    Replacement SCVs lasted just 3 months then same symptoms returned (suggesting it wasn't actually a blocked SCV)
    The only other repair suggested was a new set of injectors, but at a cost of £850 (excluding fitting) the owner decided enough was enough
    Aug 2009
    Ascot
    Does that throw up the same engine code p0093?
    Nick
    Quote Originally Posted by s2yob View Post
    No idea, the previous owner got fed up and chucked it into auction
    I saw it a few times, spoke the driver who was equally as happy as myself with the V6 CDTI as they were both 05 reg
    However, he was using his for taxi and so was more prone to short low engine temperature journeys whereas mine has longer journeys
    Ironically, mine suffered the blocked SCV first (2009) and his in 2010 (just over 12 months later)
    I diagnosed his blocked SCV as soon as I drove it and his was repaired the following month
    However, due to the vehicle usage the issue returned
    With a quoted repair of £850 he decided to cut his losses and run
    Aug 2009
    Ascot
    It's very frustrating vauxhall don't have a area technician in certain parts of the country who is trained fully in this engine, as when running correct the 1.9cdti is not in the same league
    Nick
    Thats' outrageous and a poor excuse from VX
    The one in our region is not trained on this engine, hence why he made two visits to see mine
    He made loads of phone calls on the first visit, downloaded loads of information to his laptop, and confirmed the issue very quickly on the second visit
    On the second visit he confirmed he had since been to the local Renault dealership to discuss the Y30DT engine
    Regular Member wardy's Avatar
    Chichester
    just a thought, but do issuzu fit the engine in their 3.0 4x4s? If so, wouldn't they be a good bet?
  1. 3.0 v6 cdti 2004 lack of power
    By DONNAS5889 in forum Engine & Drivetrain
    Last Post: 15th June 2011, 20:58
  2. Vectra C 150 CDTi Lack of Power
    By sclarkson82 in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2011, 21:07
  3. Help needed Lack of Low Down Power cDTI 150
    By supersione in forum Vectra C / Signum Troubleshooting
    Last Post: 24th January 2010, 19:58
  4. Lack Of Power (2004 1.9 cdti 8V)
    By user999998 in forum Engine & Drivetrain
    Last Post: 2nd June 2009, 09:03
  5. cdti 150 lack of power
    By michael cummings in forum Diesel Engine related
    Last Post: 8th February 2009, 20:44
