Thread: Brake pipes corroded.anyone help?
    Jun 2009
    Middlesex
    Default Brake pipes corroded.anyone help?
    Have noticed the two brake pipes under drivers footwell on my 2.2 direct are in poor condition and require replacement.Has anyone had these replaced before?
    Many Thanks.
    Regular Member XPCobra's Avatar
    Dec 2010
    Glasgow
    Vehicle : Vauxhall Vectra Hatch
    Trim : SRI with added X-Pack
    Engine : 1.9 16v 150
    Mileage : Near 100K
    I have replaced these before on a 2002 vectra c, normally they fail the mot (or burst in my case) near where the are sectioned at the rear ( pipe going to N/S/R wheel)
    If your doing it yourself it will cost you £10-£15 ish in pipe, fluid and brake pipe unions (if you have the tools).
    I didnt remove the rear subframe, just took my time unclipping the n/s/r pipe from the plastic clips and made a new pipe the same shape and clipped it back in.
    The pipes are also sectioned just under the drivers pedals, which is handy
    Jun 2009
    Middlesbrough
    I did all mine this year.
    I took the old pipes off the car using just drive on ramps and they cost me £26 for the pipes to be made up including fittings. Putting them back was straight forward, some where slightly long but I managed to get them fitted with very little problems.
    The one to the passengers side rear wheel was quite easy in the end, I just straightened the pipe out and pushed it through the gap to the other side. I used cable ties to keep the pipes in place where I couldnt use original fittings.
    Keep the pipes away from the anti roll bars as I was told and everything will be OK.
    Also, on mine there were different fitting sizes depending on which port on the ABS control box the pipes went into, make a note what size fitting goes in which ABS port and you shouldn't go wrong.
    Paul
    Jun 2009
    Middlesex
    Did you have the pipes made up in copper and how do you go about filling and bleeding the brakes with the abs.
    Thanks Dobs.
    Jun 2006
    St. Helens,Merseyside
    not changed any of the pipes but i did a fluid change today with my easy bleed kit,with no issues.
    Jun 2009
    Middlesbrough
    I had the pipes made up in copper by the local motor factors, they are very helpful. I have read somewhere that you are supposed to bleed the brakes with the engine running because of the ABS, dont know why but I did mine as normal like any other car and everything was OK as far as I was concerened. Rear brake pipes where completely shot especially the one going through to the passenger wheel, it fell apart in my hands but the local motor factors managed to measure it none the less.
    Paul
    East Midlands
    Grease the pipes up if there not to corroded and they'l outlive the car.
    Jun 2009
    Middlesex
    Thanks for the advice.I will try and kook at them at the weekend.
    Nov 2011
    nuneaton
    hi i am looking to do my brake pipes, what size copper pipe do i need and do i need any specialised tools .
    Jun 2009
    Middlesbrough
    If you take your old pipes to a local motor factor and ask them to make them up after they have measured your old ones they will supply you with the correct size copper pipe and flare the ends for you and put the fittings on for you.
    You only need normal DIY tools to to do the job.
    Paul
  1. Brake Pipes
    By st2malo in forum Suspension, Wheels & Brakes
    Last Post: 26th July 2012, 12:46
  2. MOT ALL brake pipes badly corroded
    By formby in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2011, 22:39
  3. corroded front and rear brake discs.
    By dazza2393 in forum Suspension, Wheels & Brakes
    Last Post: 13th December 2010, 22:45
  4. Corroded front brake pipes
    By sheepish in forum Suspension, Wheels & Brakes
    Last Post: 22nd October 2010, 14:04
  5. Brake Pipes.
    By djveccy in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2010, 00:42
