Results 1 to 3 of 3
Thread: Dreaded 'Check Safeguard' warning
    Nov 2010
    East Midlands
    Trim : design
    Default Dreaded 'Check Safeguard' warning
    Last week I had the alarm on my 1.9cdti estate keep going off and every time I turned on the ignition I would get the 'Check Safeguard' warning. Ran a diagnostic check using my diagnostic tool that I can't mention and got several faults that indicted a 'pane was broken' Checked the rear heated windscreen element and found that one of the connectors had come undone. Sorted that and also looped the two rear side window connectors as I have read they are prone to problems. Cleared the faults but was still getting the same warning message, after numerous engine restarts. Eventually I disconnected the battery for half an hour and on reconnecting it had cleared the Safeguard message. Worth bearing in mind if anyone else gets this problem.
    Engine : 1.9 CDTi
    Did you clear the codes after you bypassed the window break sensors?
    Nov 2010
    East Midlands
    Trim : design
    Quote Originally Posted by lee gsi View Post
    Yes I tried before and after bypassing them but the warning came up and wouldn't go other than disconnecting the battery. To be honest I think it was the rear screen element that was at fault but thought I would bypass the side windows while I was at it. The alarm would go of if anyone broke either of these windows as the ultrasonics would hopefully pick it up
  1. Safeguard Check!
    Last Post: 14th January 2014, 00:27
  2. Safeguard check
    By VikingLammy in forum Electrical & ICE (including SatNav)
    Last Post: 17th December 2012, 21:39
  3. safeguard check warning on dash,why?
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2012, 00:41
  4. Check Safeguard
    By DaveG in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2011, 22:51
  5. Check Safeguard
    By Dazzy2006 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2010, 10:25
safeguard vauxhall vectra
vauxhall vectra c rear heated window safe guard message
vectra c safeguard warning
vectra c safeguard message
vauxhall signum check safeguard message
vauxhall safeguard
vauxhall vectra c check safegaurd fault
how do u get rid of check safeguard warning on vauxhall vectra
safe guard message on vauxhall vectra
vauxhall vectra safeguard check
vectra c check safeguard
cant clear safeguard from vauxhall vectra
vectra c.dash warnibg safeguard
https:www.vectra-c.comforumshowthread.php150282-Dreaded-Check-Safeguard-warning
vectra c safeguard warning and windows keep going down
vectra 1.9 cdti alarm keeps going off
safe guard check vectra c
safeguard opel vectra
vauxhall vectra check safeguard message
safeguard fault vectra c
vauxhall check safeguard
safeguard message on vectra
vectra c safeguard
how to bypass safeguard on a vectra c
