Thread: Vectra C Headlight Motor Trouble !
    Regular Member Elahi_786's Avatar
    Oct 2010
    Bedford
    Exclamation Vectra C Headlight Motor Trouble !
    Hi All...
    Hope your all !!
    My Vectra C Headlight motor on the passenger side has gone after checking via AA, makes a massive rattling sound. I need to replace it and wondered if there was a how to do? I know I have to remove the bumper.
    Many Thanks
    Elahi
    Engine : 1.9 CDTi
    Once you have a replacement motor and the headlight you will see how it comes out.
    From memory you twist the motor then tilt it as you remove it out the locator in the headlight.
    Oct 2010
    Bedford
    Thumbs up Reply
    Thanks for the reply, I am only replacing the motor not the headlight but I have been told that I need to drop the bumper and then remove the headlight and I need a how to do on that if its available or in bits of how to remove headlight and how to remove bumper etc.
    Regards
    Elahi
    Engine : 1.9 CDTi
    I think there is a guide in the guides section
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    As yours is pre facelift you can get away with undoing the clip under the bonnet on the bumper near the headlight you want to remove and if you undo the screws on the same side at the wheel arch. Pull the bumper outwards from the side fo the car there is enough room if you have a driver short enough to undo the bolt under the head light. The other two bolts are on top the headlight - after all three are removed undo the headlight loom - slide the maroon lever on the plug and it will become free. Headlight can be removed from the car.
    Oct 2010
    Bedford
    Thank you guys...
    Is there a how to do this? I can not seem to find it and would help greatly.
    Many Thanks
    Elahi
  1. Motor Blower trouble, epic bodge job from previous owner!
    By user999999 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2011, 10:18
  2. headlight motor!
    By kenp in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2011, 18:56
  3. Headlight alignment and VX dealer trouble
    By merikiito in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2008, 21:14
vectra c headlight motor removal
vauxhall vectra c headlight motor extension
headlight motor vaxhall vectra c forum
