Results 1 to 10 of 20
Thread: 2004 2L dti white smoke problem please help
    Jul 2010
    Bolton
    Default 2004 2L dti white smoke problem please help
    i have 2004 estate with 94000 miles on the clock about a year ago I started it up drove round corner noticed a lot of white smoke so pop in to local garage. the only code that came up was throttle position senser so changed it. still the same problem.Second option injectors so changed all injectors and seals at a cost of £450 and still the same problem.
    after this these are a list off item that have been replaced
    A Second hand Turbo to replace the old one
    Pre heater Canister (Fuel filter housing)
    Glow Plugs and second hand Glow plug Relay
    Leak off Pipes and connectors
    turbo inter cooler cleaned out and pipes checked for damages
    temp and crank sensers changed
    Vacuum pipes and actuators changed
    egr valve (second hand) changed
    inlet manifold and swirly flaps
    New Battery
    and still the same Problem
    left it running for 20 minutes and noticed the smoke has gone so I switched it off tried it again not a problem.Next day started it to take it for M O T same problem this time i noticed
    When Starting for the first 20 sec just tiny amount of smoke just like a diesel will then engine changes tone and cloud of white smoke just pour out of back box.When left idling and as soon as the temperature goes up to 80 on temp gauge the engine runs normal and no smoke.
    so took plug off temp senser so fan kicks in after temp started going down i notice the smoke started again
    please any one direct me what it could be there is no engine management light on either
    If you are not having to top up the coolant I would guess that the white smoke you are seeing is condensation caused by hot exhaust gas passing through a cold exhaust system.
    wirral
    31 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    Is it using oil?
    New Member melvyn8181's Avatar
    Jul 2011
    north lincolnshire
    Welcome to the ownership of a dti, mine smokes a little, I changed fuel filter a short while ago and that made a diffence.
    Jul 2010
    Bolton
    thanks for replying gave it a service with new oil, oil filter and fuel filter am not losing any coolant or oil been told it could be over fuelling
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    The only one you haven't mentioned is the MAF sensor. If this is running faulty it could be the issue. Although diesels are not as strict with Air to fuel ratios as petrols, they are designed to run at a particular AFR at a given throttle position. If the MAF is telling the ECU more air entering the engine than is actually, then the engine will over fuel. That's my theory anyway.
    Insignia VX-Line Nav CDTI 170.
    Jul 2010
    Bolton
    Nice one Gazza will try over weekend mate and post results
    Jul 2010
    Bolton
    Quote Originally Posted by Gazza4 View Post
    replaced MAF and still same Problem any more ideas could it be it needs a software update
    wirral
    31 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Oxygen sensor faulty?
    Full Member
    Bristol
    White smoke for a diesel is air in system . leak off pipes or injector seals.
  1. Replies: 18
    Last Post: 20th November 2012, 21:41
  2. white smoke help
    By smartalec0310 in forum Engine & Drivetrain
    Last Post: 29th June 2012, 22:59
  3. white smoke help
    By smartalec0310 in forum Styling
    Last Post: 25th June 2012, 18:32
  4. White smoke!
    By stickygreen in forum Engine & Drivetrain
    Last Post: 1st February 2012, 19:02
  5. White Smoke Problem 2004 2L DTI
    By sanjaypatel2000 in forum Engine & Drivetrain
    Last Post: 14th November 2011, 22:54
vectta c 2.0 dti white smoke wont rev over
