Thread: Fault code help :(
    Regular Member Thom's Avatar
    Nov 2010
    UK
    Default Fault code help :(
    I've got these nasty little things floating about my 2.0 dti club. They make me quite sad! I've tried contact cleaner on the steering controls, cruise control swtch and my driver door controls but alas, no improvement. The rest i have no idea about so appreciate all the help i can get!
    B3840 - Wrong Stalk Switch Configuration
    (00) - Present
    B3840 - <Unknown DTC>
    (0F) - Present
    B3794 - Switch Cruise Control Circuit Open or High Voltage
    (04) - Present
    B2810 - Steering Wheel Remote Circuit Open or High Voltage
    (04) - Present
    U2105 - CAN-Bus ECM Message Range/Performance
    (71) - Not present
    U2107 - Invalid Data from BCM (Body Control Module)
    (71) - Present
    B2996 - Rear Left Door Switch Circuit Open or High Voltage
    (05) - Present
    B3974 - Driver Door Select Switch Window Lifter Circuit Open or High Voltage
    (05) - Present
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Hav u got them codes with a opcom
    Engine : 1.9 CDTi
    Clear them and start again.
    Nov 2010
    UK
    I have used an op-com and that is a cleared list, cleared and rescanned for that matter
    Dec 2011
    Larkfield
    I have checked mine tonight as i had been having problems with CC keep turning itself off, i followed advice on here with regards to cleaning and ultimately replaced the stalk in the end, Still doesn't work so my next check is the micro switches on the brake and clutch,
    However i have read your post and found we have a similar fault code
    B3794-04 Switch cruise control open or high voltage.
    I also have the following
    B2930-05 Anti theft warning system disable circuit open of high Voltage.
    I have reset my fault codes which were minimum but the above 2 kept coming back immediately!!!
    The cruise control was working intermittently until i disconnected the battery a few weeks ago and then stopped totally.
    Hope someone on here can help coz im totally stumped!!!
    Dec 2011
    Larkfield
    confused Cruise control open or High voltage B3794-04
    Bristol
    if you use an old version of op-com it will show tiny errors if you get new version this does no show them, it works like snop-on and tech 2 .
  1. Fault code help!
    By joee91 in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2012, 00:52
  2. Fault code help!!!
    By billy88 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd April 2011, 16:02
  3. help with a fault code
    By jan65uk in forum Engine & Drivetrain
    Last Post: 15th December 2009, 20:57
  4. Fault Code?
    By CDTi-SRi-Matt in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2009, 21:43
  5. Fault Code?
    By CDTi-SRi-Matt in forum Electrical & ICE (including SatNav)
    Last Post: 26th February 2009, 21:23
Opel fault B2996
Opel DTC B3794-1
Opel DTC B3794-04
DTC opel B3840
Opel B3794
vectra c b3794
b3794-04 fault code opel
Vauxhall B3840
b3794 fault code
vauxhall vectra fault code b3794
Opel B3840
