Thread: car feels like wheels 'wandering'
    Regular Member 2.2 oil burner's Avatar
    Oct 2007
    wales
    Vehicle : Sri
    Trim : Xp
    Engine : 1.9 cdti 150
    Default car feels like wheels 'wandering'
    I have owned my Sri with Xp kit now for about 18months. I noticed straight away that it had a tendancy to wander over uneven surfaces and was told it was because of the wide 19" low-profile tyres. It's slowly got worse to the point you are constantly having to correct the steering whether it be over slightly uneven roads or when breaking hard, and when pushing hard in the twisties alternates from over to under-steering. It passed the mot in July with no problems so what should i be looking for? Obvious one is the trackrod ends but is there anything else to check?
    morecambe
    44 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    checck tyre pressures mate its called tramming all wide alloys do it
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    and when was the last time you had the tracking done (it needs a four wheel alignment)
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    As above mate. It's best to get Alignment checked every year.
    newport
    i had that on my preface and it was the tracking.
    i would be driving along in a straight line, and it felt as if one wheel all of a sudden would find a trench in the road to follow rather than the way the car wanted to go, always happened without expecting it and i had to suddenly correct it. had the tracking sorted, and its never happened since
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Could also be worn wishbone bushes too.
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    I have 19s and get this too... I do get the 4 wheel laser alignment done atleast yearly, and my struts are pretty much all new as replaced everything myself! Its down the alloys mate, every car I have had with low profiles has tended to get pulled with camber and ruts in the road.
    Get that 4 wheel alignment done too I always get it done by someone with the laser machines as its super accurate!
    Oct 2007
    wales
    Vehicle : Sri
    Trim : Xp
    On my third set of tyres on the front and second set on back and they wear pretty even. Guy in tyre place said its down to the tyre width but beemers etc have wide tyres fitted as standard and i bet they don't drive ****. Tending to wander now on nearly dead smooth roads, think i need to get it laser alligned then.
    How do you check the wishbones?
    It also wanders badly when going over white lines. Pressures are as handbook- 39psi front, 36 psi rear for the 1.9cdti
    Last edited by 2.2 oil burner; 14th November 2011 at 23:16. Reason: adding something
    Jun 2011
    west mids
    could be your inner tie rods have got play in them so when aligned properly its still out,ive got this problem but soon to rectify with new inner arms from vx
    Oct 2007
    wales
    Vehicle : Sri
    Trim : Xp
    By inner tie rods do you mean the track rods?
  1. Wandering during heavy braking ?
    By mickyh7 in forum Vectra C / Signum Car Chat
    Last Post: 23rd June 2012, 12:00
  2. Feels like un-balanced.... but..
    By chewy71 in forum Suspension, Wheels & Brakes
    Last Post: 17th November 2010, 13:43
  3. Two guys wandering around a garage full of old cars
    By VXR_DV in forum The 'Off Topic' room
    Last Post: 2nd July 2010, 15:24
  4. Feels like a new car!
    By @ndy-e in forum Quick Photo Album
    Last Post: 2nd November 2009, 01:40
  5. Wandering Car
    By mattydti16v in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2007, 23:41
