Thread: f40 drain plug access
    Regular Member justin32's Avatar
    Aug 2011
    Basingstoke
    Vehicle : Vectra c SRI Facelift
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default f40 drain plug access
    Do i need to take the belly pan off the car to get to the f40 drain plug or can i get to it by just dropping the service hatchy thingy as in an engine oil change?
    Planning on changing my gearbox oil at the weekend.
    The cars a veccy c facelift 1.9cdti 150
    Jul 2009
    Brighton
    How did you get on with this?
    I've been meaning to do it for ages.
    Did you replace the filler/drain plugs?
    yes you have to take the belly plate off to access it
    and when you do it make sure you change the drain plug as the new one has a different type of sealing washer on it
    dont need to change the fill plug but good luck getting them undone
    oh and make sure you can remove the fill plug BEFORE undoing the drain plug !!!!!!
    May 2008
    newcastle
    changed my gearbox oil at the weekend, had to use a chisel to get the drain plug loosened off, you can fill it up without removing the battery box, all you need is a length of garden hose with some 15mm copper pipe in the end to fit in the plug hole & a funnel on the other end.
    Good luck
    South east
    Jul 2009
    Brighton
    Smile
    Just done mine. Both the fill plug and the drain plug came out easily. Both 8mm hex sockets.
    I replaced the drain plug with a new one (P/N 11099271 - Torx 45).
    I'd recommend taking the battery tray out as per the how 2, makes it much easier.
    Put 2.2 litres back in and a tube of molyslip. Better already.
  1. Wheres my drain plug
    By datiger79 in forum Engine & Drivetrain
    Last Post: 11th June 2012, 15:31
  2. Oil Drain Plug Vectra C 2l Dti
    By dc6839 in forum Engine & Drivetrain
    Last Post: 6th July 2011, 08:17
  3. gearbox drain plug
    By collyb in forum Engine & Drivetrain
    Last Post: 3rd May 2011, 13:47
  4. Drain Plug - Coolant
    Last Post: 22nd June 2009, 13:53
  5. oil drain plug ?
    By dmoffat in forum Engine & Drivetrain
    Last Post: 17th June 2008, 10:27
