Results 1 to 3 of 3
Thread: fuse help
    Aug 2011
    norfolk
    Default fuse help
    hi,im looking for some help with a couple of fuses,number plate one and high lvl break light one(if there is one).
    The number plate lights dont work,ive tryed changing the bulbs but no joy,does anyone know what number it would be and which box it would be in?
    Same with the break light if possible thanks.
    nearly forgot,,its an 03 vectra sri
    Aug 2011
    norfolk
    next option is to wire the number plate lights to the rear lights,but i know nothing about electrics,anyone able to help with this?
    May 2008
    Tyneside
    The Haynes wiring diagram shows these lights fed from the electronic control unit in the rear fusebox. There are no fuses shown which feed this unit and with it being controlled via the canbus system any mods could cause problems, not least with the bulb failure system. I'd check the plug on the electronic control unit is secure. HTH
  1. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  2. help fuse box
    By steve19cdti in forum Electrical & ICE (including SatNav)
    Last Post: 9th August 2011, 19:24
  3. What does fuse 26 do in the engine compartment fuse box?
    By rich05uk in forum Troubleshooting
    Last Post: 8th January 2011, 22:02
  4. fuse box ID
    By myelite150 in forum Electrical & ICE (including SatNav)
    Last Post: 19th December 2009, 13:17
  5. Which fuse?
    By Adam in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2007, 09:41
