Thread: Hlep!!
    Nov 2011
    cornwall
    Default Help!!
    Hello,
    i just got my vectra back from a 400 mile driver i noticed these problems would anyone be able to help
    engine check light is on but engine running fine
    drivers window has fallen off the runner
    rear passengers side door is shut but my car thinks its not and keeps beeping
    check oil light came on but has oil half way up the dip stick
    if i lock the car with the fob it wont unlock with the fob and the alarm will go off if i use the key the fob has a red led showing that its working but not unlocking the car
    Im also looking for a set of front headlights and a front bumper and drivers wing has to be in black would love to have the sri kit on her
    any ideas on what they could be??
    Ray
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    With regards to the lights appearing on the dashboard and going out yet everything physically checks out as ok; that could be a few sensors or a module (CIM/Body control) may be on the road out - not 100% sure tbh.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Engine check is probably in conjunction with the oil light.
    So top up the oil. And see if that makes a difference.
    And the lock thing might be to do with the car still thinking the rear door is open.
    I believe the sensors are located in the door them selves. So maybe take door card off and try an clean electrical contacts.
    As for drivers window. You'll prob need new runner/ regulator
    Nov 2011
    cornwall
    thanks im going up to the collage today to get them to check the oil pressure as a friend had a astra 1.8 and his oil light turned out to be high oil pressure which inturn broke his engine
